Candle Oscillator Really Heats Things Up
As the timebase for a clock, almost anything with a periodic oscillation can be used. Traditionally, that meant a pendulum, but in our time, we’ve seen plenty of others. Perhaps none as unusual as [Tim]’s candle flicker clock, though.
Candles are known for their flickering, a property of the wick and the fuel supply that candle manufacturers have gone to great lengths to mitigate. If you bring several of them together, they will have a significant flicker, with a surprisingly consistent 9.9 Hz frequency. This is the timebase for the clock, with the capacitance of the flame being sensed by a wire connected to a CH32 microcontroller, and processed to produce the required timing.
We like this project, and consider it a shame that it’s not an entry in our One Hertz Challenge.  Oddly, though, it’s not the first candle-based oscillator we’ve seen; they can even be turned into active electronic devices.
11 thoughts on “Candle Oscillator Really Heats Things Up
  1. oh that’s neat but it wasn’t what i was expecting :)
    i was thinking of a mechanism that assumes a relatively constant heat source and nonetheless oscillates. like a thermal version of the drinking bird. maybe a bimetalic strip with some mechanical hysteresis added
    1. I’m surprised they don’t specifically engineer candles to flicker, since they’re mostly used for decorative and traditional purposes.
      But then again, it seems like a really surprising number of people still use them regularly as emergency lighting.
Leave a Reply to Erik JohnsonCancel reply
