We have seen many scam USB chargers appear over the years, with a number of them being enthusiastically ripped apart and analyzed by fairly tame electrical engineers. Often these are obvious scams with clear fire risks, massively overstated claims and/or electrocution hazards. This is where the “600W” multi-port USB charger from AliExpress that [Denki Otaku] looked at is so fascinating, as despite only outputting 170 Watt before cutting out, it’s technically not lying in its marketing and generally well-engineered.
The trick being that the “600W” is effectively just the model name, even if you could mistake it for the summed up output power as listed on the ports. The claimed GaN components are also there, with all three claimed parts counted and present in the main power conversion stages, along with the expected efficiency gains.
While testing USB-PD voltages and current on the USB-C ports, the supported USB-PD EPR wattage and voltages significantly reduce when you start using ports, indicating that they’re clearly being shared, but this is all listed on the product page.
The main PCB of the unit generates the 28 VDC that’s also the maximum voltage that the USB-C ports can output, with lower voltages generated as needed. On the PCB with the USB ports we find the step-down converters for this, as well as the USB-PD and other USB charging control chips. With only a limited number of these to go around, the controller will change the current per port dynamically as the load increases, as you would expect.
Considering that this particular charger can be bought for around $30, is up-front about the limitations and uses GaN, while a genuine 300 Watt charger from a brand like Anker goes for $140+, it leads one to question the expectations of the buyer more than anything. While not an outright scam like those outrageous $20 ‘2 TB’ SSDs, it does seem to prey on people who have little technical understanding of what crazy amounts of cash you’d have to spend for a genuine 600 Watt GaN multi-port USB charger, never mind how big such a unit would be.
PhD in Mathematics is just my DJ name 😂
And big10inch is my more truthful user name, but I don’t like to brag.
Deceptive marketing at its finest. 🙄
Technically correct, the best kind of correct :| Reminds me of Novoo GaN charger Gough Lui tested some time ago https://goughlui.com/2025/08/24/review-teardown-novoo-rg68-usb-c-x2usb-a-67w-gan-wall-charger/ Gan (real parts!) running hot and will lesser efficiency than high quality traditional chargers, plus dropping to 70ties% on 5V loads.
1980’s truth in advertising: “Made in Usa”… Japan.
It reminds me of the “homemade” doughnuts which were actually made in a foreign country called Homemade (pronounced “home-eh-mah-day”…
Technically all you need to do is provide an apartment for factory workers and anything is ‘homemade’
Like the infamous “Made in Sheffield” knives which was the company name in China.
A 170W charger with that many ports sounds great for travel at $34. Plus, now you’ve got someone that’s done a teardown of it. Honestly, I think I’ll get one now.
But I wouldn’t trust this thing not to catch on fire.
Catching fire is a feature
Assuming you drive 60w to 100w in a typical scenario there’s some “engineering safety margin”
I would be more concerned about the regulator malfunctioning and blasting some expected voltage over PD. Any savings in a cheap charger are quickly gone….
Even name brand stuff catches on fire sometimes. In practice this stuff tends to be reference designs anyway. I found one of these using aliexpress image search. I’ll have one in a few weeks. Plus, only $34 right now.
The other main thing to worry about is the isolation. A poorly made transformer can have an insulation breakdown resulting in the USB ground being raised hundreds of volts above earth ground. That could electrocute someone if it’s not used on an RCD/GFCI protected circuit, not to mention blowing up any grounded equipment it gets plugged into.
also quality control. just because they build one good one doesn’t mean the rest of them will be built to those standards
I’ve been using this 100W charger for a year and a half every day including charging my power bank at 90W and it’s been flawless.
The only problem with it is it renegotiates every time you plug an additional thing into one of the 4 ports causing each thing to stop and start charging again. Only a problem if you use it to power a SBC or something as it will reboot when plugging another device into it.
Can’t be beat for about $13, don’t discount all inexpensive GaN chargers.
https://a.co/d/4iOABTJ
My friend bought a ‘500,000mah’ power bank a few years ago. I did point out (even at 3 volts let alone 12) that it’d have to be way bigger than a. car battery. Indeed 500,000mah was the brand name LOL.
If you add up the numbers on the 8 ports it equals 600…
And yet the ports are shared and pd drops, making it impossible to ever reach that “total”. It’s written up there that even product page says so.
So, if they’re $30/each – just buy three of them.
