2025 Component Abuse Challenge: A Self-Charging LED Flasher By Burkhard Kainka
A hand holding the circuit in its active state
[Tito] entered a Self-Charging LED Flasher into the Component Abuse Challenge. It’s a simple re-build of a design by the unstoppable [Burkhard Kainka], and while [Tito] doesn’t explain its workings in detail, it’s a clever experiment in minimalism, and a bit of a head-scratcher at the same time.
You press a button and an LED flashes.  But there is no battery, so how does it work? Maybe the schematic to the right here will help. Or does it confound? Look at it yourself before reading on and see if you can figure out how it works.
The answer is that when the switch is open the LED functions as a small solar cell, drawing power from ambient light. This power is stored in the capacitors and released when the switch is closed! Pretty nifty.
We thought this circuit looked like fun so we took it over to the bench and put it together on veroboard. It took us a few goes to get it right. We used 100 nF ceramic caps to begin with, but didn’t get good results. So we switched to 1 µF polypropylene film capacitors and when we did that we got the circuit to work. It was possible to charge the circuit sufficiently using a mains powered LED lamp we have in the lab, a minute or so sitting in front of that charged the capacitors sufficiently to generate a flash. If you give this circuit a go yourself we’d love to hear how it went for you in the comments! (Editor’s note: Low leakage current in the capacitors is probably the trick.)
Of course we’ve seen plenty of self-powered circuits here at Hackaday before, such as this self-powered camera and this self-powered paper keyboard.
And if you haven’t checked out [B. Kainka]’s website, you’re missing out on enough weekend projects to last you for the rest of your life, if you live that long.  (Translated from German here.) Some of his simple, yet brilliant, builds have even graced our pages here: this classic op-amp meower, or this clever radio receiver that uses an LED, biased by the PWM output of an ATtiny13, as a detector. Maybe [Burkhard] himself should enter the contest?
8 thoughts on “2025 Component Abuse Challenge: A Self-Charging LED Flasher By Burkhard Kainka
  1. The simple explanation is that the two capacitors are charged in parallel by the LED, then connected in series by the switch, which pushes current through the LED until the capacitors are half-discharged.
    This is a simple charge pump that takes the voltage produced by the diode and doubles it for a short flash.
Leave a Reply to Conor StewartCancel reply
