Following up on the recent test of a set of purported ADS1115 ADCs sourced from Amazon [James Bowman] didn’t just test a genuine Ti part, but also dug into some of the questions that came up after the first article. As expected, the AdaFruit board featuring a presumed genuine Ti ADS1115 part performed very well, even performing significantly better on the tested parameters than the datasheet guarantees.
Thus we can confirm that when you get the genuine Ti part, you can expect very good and reliable performance for your ADC purposes. Which leaves the unaddressed questions about what these cheapo Amazon-sourced ADS1115 ICs are, and how it can be that LCSC has what should be the same parts for so much cheaper than US distributors?
As far as LCSC pricing is concerned, these are likely to be genuine parts, but also the subject of what is known as price discrimination. This involves pricing the same product differently depending on the targeted market segment, with e.g. Digikey customers assumed to be okay with paying more to get the brand name assurance and other assumed perks.
Regarding the cheapo parts off Amazon, these could be QA failed parts, ‘third shift’ or other grey zone parts being sold for less, as well as outright fakes. The Analogy ADX111 for example is basically a drop-in clone of the ADS1115, down to parts of the datasheet, with the heading image showing a section to compare the two. Interestingly, the ADX111 is sold for $1.77 in 1,000 quantities on LCSC.
Ultimately it’s hard to tell the true origin of the ‘ADS1115’ ICs on one of these cheap boards. They could have fallen off a genuine ADS1115 production line, be QA failed ADX111 parts or something else entirely. Without decapping a few samples and further in-depth research we’ll likely never know.
Yet as some already commented, does it truly matter? You get the cheapo parts when you’re just screwing around with a prototype rather than splurging for the gold-plated AdaFruit version, and source from LCSC or Digikey when it’s time for PCBA. In the end everyone is happy, even without knowing whether it’s truly meat a Ti part that we’re using.
Concerning the question of “does it truly matter?”
My answer is yes, it matters, and it matters a lot.
When you’re buying something that is claimed to be a Ti ADC1115 and it is not, then it is fraud. Simple as that. No excuses, and if I discover such a thing then I always give negative feedback.
If some “shady shop” advertises wit ADS1115, but they “somewhat clearly” state that it is some alternative part, then I’m OK with that. Then It’s my choice whether I want to go with a cheaper part that may have different or lesser specifications.
My motivation:
The “blue pills” have been completely broken. A bunch of years ago they cost around EUR 4 and they were quite nice development boards. And then the fakes arrived. The parts could be from about 6 different manufacturers (APM, GD to name a few), but the original type numbers were erased and these parts are not 100% compatible. One difference is that one of the clones has a long startup time because it loads the whole program into RAM at startup, and then it can run at a higher clock frequency. But if they erase the type numbers and print on “STM32” Then you’re left in the dark, and you have to go figure out what parts you bought this week after they arrived on your doorstep.
WeAct is a company I quite like. They still sell the “Blue Pills” and in different variants, and they clearly state which version you get on their aliexpress shop.
I also bought some BJT’s TIP41 and 2SC5200 on aliexpress, and they all turned out to be fake. The transistors simply exploded (Under the microscope: molten bondwires) at less then half the rated current of those transistors. The Collector Emitter voltage of the 2SC5200 was also much lower as the datasheet. They went into avalanche at 120V. (Should be > 230V).
There were ever legitimate stm32 blue pills? haha nothing personal but i don’t happen to believe it. Anyways that’s why i love the pico rp2040. It’s so cheap even when purchased through reputable dealers
Texas Instruments abbreviates the name as TI. This also follows the normal rules for an initialism.
https://www.ti.com/about-ti/company/ti-at-a-glance.html
https://www.grammarly.com/commonly-confused-words/acronym-vs-initialism
“Ti” is incorrect, both by the Texas Instruments website and by the normal rules of grammar.
Ti is fake TI :o)
People use the letters “Ti” only because it looks better and it does not looks like a “TL” (Tl) with many fonts.
Sans fonts are the worst. There are many modern trends that inhibit language skills, but the rise of ambiguous fonts is the trend that bothers me the most.
Yes, I wrote a browser plugin to convert everything to TNR, but there are still plenty of places (particularly on mobile) where that does not help.
Not only do sans fonts have ambiguous characters, they are also ugly as hell! Back in my day… Mumbles old man complaints while shaking my cane at the sky
