Making Audible Sense Of A Radiation Hunt
The clicking of a Geiger counter is well enough known as a signifier of radioactive materials, due to it providing the menacing sound effect any time a film or TV show deals with radiation. What we’re hearing is the electronic detection of an ionization event in a Geiger-Muller tube due to alpha or beta radiation, which is great, but we’re not detecting gamma radiation.
For that a scintillation detector is required, but these are so sensitive to background radiation as to make the clicking effect relatively useless as an indicator to human ears. Could a microcontroller analyse the click rate and produce an audible indication? This is the basis of [maurycyz]’s project, adding a small processor board to a Ludlum radiation meter.
When everything sounds like a lot of clicks, an easy fix might be to use a divider to halve the number and make concentrations of clicks sound more obvious. It’s a strategy with merit, but one that results in weaker finds being subsumed. Instead the approach here is to take a long-term background reading, and compare the instantaneous time between clicks with it. Ths any immediate click densities can be highlighted, and those which match the background can be ignored. SO in goes an AVR128 for which the code can be found at the above link.
The result is intended for rock prospecting, a situation where it’s much more desirable to listen to the clicks than look at the meter as you scan the lumps of dirt. It’s not the first project in this line we’ve brought you, another one looked at the scintillation probe itself.
11 thoughts on “Making Audible Sense Of A Radiation Hunt
  1. I think you got that wrong my love. Alpha is helium atoms, beta is electrons and gamma is photons – and only photons pass through glass of GM tube. Scintilatsiya detectors are the ones used for alpha and beta. Next time less youtube more book friend.
      1. Most GM tubes do not detect Alpha. Some GM tubes will detect the associated Gamma from the Alpha decay and Beta/Gamma decay of daughter products in the decay chain.
        Simply showing a meter detects something near an Alpha source doesn’t mean it is detecting the Alpha.
        /Senior Radcon tech with experience with BWR and Graphite Production reactors, Chem reprocessing, and Nuclear Demolition.
  2. Dearest Jenny,
    Most GMs only detect Beta and Gamma radiation. A few can detect Alpha. All detect Gamma. All of this is determined by the density thickness of the GM tube walls. Very thin walled tubes can detect Alpha. Slightly thicker tube walls will block Alpha and allow the more penetrating Beta and Gama pass. Other tubes have walls thick enough to exclude all but Gamma. Some tubes have a movable shield allowing the user to block one or more of the weaker penetrating radiations so it can be determined how much of each type contributed to the unshielded total reading.
    The main point is all GM tubes measure Gamma radiation.
    1. The main point is all GM tubes measure Gamma radiation.
      Thank you so much! After reading the first few lines of the article, I initially thought that the history of physics would have to be rewritten for hackaday ;-)
Leave a Reply to DerAxemanCancel reply
