The Deadliest US Nuclear Accident Is Not What You Think
When you think of a US Nuclear accident, you probably think of Three Mile Island. However, there have been over 50 accidents of varying severity in the US, with few direct casualties. (No one died directly from the Three Mile Island incident, although there are some studies that show increased cancer rates in the area.)
Indeed, where there are fatalities, it hasn’t been really related to the reactor. Take the four people who died at the Surry Nuclear Power Plant accident: they were killed when a steam pipe burst and fatally scalded them. At Arkansas Nuclear One, a 525-ton generator was being moved, the crane failed to hold it, and one person died. That sort of thing could happen in any kind of industrial setting.
But one incident that you have probably never heard of took three lives as a direct result of the reactor. True, it was a misuse of the reactor, and it led to design changes to ensure it can’t happen again. And while the incident was nuclear-related, the radiation didn’t kill them, although it probably would have if they had survived their injuries.
Background
The large cylinder housed the SL-1 reactor. The picture is from some time before the accident (public domain).
It may be a misattribution, but it is often said that Napoleon said something like, “An army marches on its stomach.” A modern army might just as well march on electrical power. So the military has a keen interest in small nuclear reactors to both heat sites in cold climates and generate electricity when in remote locations or in, as they like to call it, denied areas.
In the mid-1950s, the Army tasked Argonne National Laboratory to prototype a small reactor. They wanted it portable, so it had to break down to relatively small pieces, if you consider something weighing 10 tons as small, and could be set up in the field.
The resulting prototype was the Stationary Low-Power Reactor Number One, known as SL-1, operated by the Army in late 1958. It could provide about 400 kW of heating or 200 kW of electricity. The reactor core was rated for 3 MW (thermal) but had been tested at 4.7 MW a few times. It would end operations due to an accident in 1961.
Design
Sketch of the reactor internals (public domain).
The reactor was a conventional boiling-water reactor design that used natural circulation of light water as both coolant and moderator. The fuel was in the form of plates of a uranium-aluminum alloy.
The reactor was inside a 48-foot-tall cylinder 38.5 feet in diameter. It was made of quarter-inch plate steel. Because the thing was in the middle of nowhere in Idaho, this was deemed sufficient. There was no containment shell like you’d find on reactors nearer to population centers.
The reactor, at the time of the accident, had five control rods, although it could accommodate nine. It could also hold 59 fuel assemblies, but only 40 were in use. Because of the reduced number of fuel plates, the reactor’s center region was more active than it would have been under full operation. The rods were eight in a circle with four dummies and a ninth one in the center. Because of the missing outer rods, the center control rod was more critical than the four others.
The Accident
In January of 1961, the reactor had been shut down for 11 days over the holiday. In preparation for restarting, workers had to reconnect the rods to their drive motors. The procedure was to pull the rod up four inches to allow the motor attachment.
Cutaway of the SL-1 and the control building (public domain).
There were three workers: Specialist Richard McKinley, Specialist John Byrnes, and a Navy Seabee Electrician First Class Richard Legg. Legg was in charge, and McKinley was a trainee.
From a post-accident investigation, they are fairly sure that Byrnes inexplicably pulled the center rod out 20 inches instead of the requisite four inches. The reactor went prompt critical, and, in roughly four milliseconds, the 3 MW core reached 20 GW. There wasn’t enough time for sufficient steam to form to trigger the safeties, which took 7.5 milliseconds.
The extreme heat melted the fuel, which explosively vaporized. The reactor couldn’t dissipate so much heat so quickly, and a pressure wave of about 10,000 pounds hit the top of the reactor vessel. The 13-ton vessel flew up at about 18 miles an hour, and plugs flew out, allowing radioactive boiling water and steam to spray the room. At about nine feet, it collided with the ceiling and a crane and fell back down. All this occurred in about two seconds.
As you might imagine, you didn’t want to be in the room, much less on top of the reactor. Two of the operators were thrown to the floor. Byrnes’ fall causes his rib to fatally pierce his heart. McKinley was also badly injured but only survived for about two hours after the accident. Legg was found dead and stuck to the ceiling, an ejected shield plug impaling him.
Why?
Actual photo of the destroyed reactor taken by a camera on the end of a crane.
You can place a lot of blame here. Of course, you probably shouldn’t have been able to pull the rod up that far, especially given that it was carrying more of the load than the other rods. The contractor that helped operate the facility wasn’t available around the clock due to “budget reasons.” There’s no way to know if that would have helped, of course.
But the real question is: why did they pull the rod up 20 inches instead of four? We may never know. There are, of course, theories. Improbably, people have tried to explain it as sabotage or murder-suicide due to some dispute between Byrnes and one of the other men. But that doesn’t seem to be the most likely explanation.
Apparently, the rods sometimes stuck due to misalignment, corrosion, or wear. During a ten-month period, for example, about 2.5% of the drop-and-scram tests failed because of this sticking: a total of 40 incidents. However, many of those causes only apply when the rods are automatically moved. Logbooks showed that manual movement of the rods had been done well over 500 times. There was no record of any sticking during manual operations. Several operators were asked, and none could recall any sticking. However, the rate of sticking was increasing right before the incident, just not from manual motion.
However, it is easy to imagine the 48-pound rod being stuck, pulling hard on it, and then having it give way. We’ve all done something like that, just not with such dire consequences.
Aftermath
First responders had a difficult time with this incident due to radiological problems. There had been false alarms before, so when six firefighters arrived on the scene, they weren’t too concerned. But when they entered the building, they saw radiation warning lights on and their radiation detectors pegged.
Even specialized responders with better equipment couldn’t determine just how much radiation was there, except for “plenty.” Air packs were fogging, limiting visibility. During the rescue of McKinley, one rescuer had to remove a defective air pack and breathe contaminated air for about three minutes. Freeing Legg’s body required ten men working in pairs, because each team could only work in the contaminated zone for 65 seconds. The rule had been that you could tolerate 100 Röntgens (about 1 Sv or 100 rem) to save a life and 25 (0.25 Sv or 25 rem) to save valuable property. Of the 32 people involved in the initial response, 22 received between 3 and 27 Röntgens exposure. Further, 790 people were exposed to harmful radiation levels during the subsequent cleanup.
The reactor building did prevent most of the radioactive material from escaping, but iodine-131 levels in some areas reached about 50 times normal levels. The remains of the site are buried nearby, and that’s the source of most residual radiation.
Lessons Learned
Unsurprisingly, the SL-1 design was abandoned. Future designs require that the reactor be safe even if one rod is entirely removed: the so-called “one stuck rod” rule. This also led to stricter operating procedures. What’s more, it is now necessary to ensure emergency responders have radiation meters with higher ranges. Regulations are often written in blood.
The Atomic Energy Commission made a film about the incident for internal use but, of course, now, you can watch it from your computer, below.
You might also enjoy this presentation by one of the first responders who was actually there, which you can see below. If you want a more detailed history, check out Chapters 15 and 16 of [Susan M. Stacy’s] book “Proving the Principle” that you can read online.
Nuclear accidents can ruin your day. We are always surprised at how many ordinary mistakes happen at reactors like Brown’s Ferry.
47 thoughts on “The Deadliest US Nuclear Accident Is Not What You Think
  1. We obviously don’t have the full background, but something seems a little odd here.
    Knolls had been making small, transportable reactors for some years before this (for the “electric boats”). Argonne was even involved. You have to wonder why they felt they needed to reinvent the wheel here.
    Maybe the different services were siloed?
    1. Different fuel loads, different size, different capabilities, different Service branch.
      SL-1 was designed in 54-55, Nautilus was 54-55 and it was a Proof of Concept effectively for Nuclear Submarines for the US Navy.
      SL-1 was for the US Army.
      1. The SL-1 was supposed to be a prototype “pathfinding” reactor that in a refined design, would be self-contained and transportable by truck, sea, or air to power facilities in the Canadian tundra and arctic for the Mid-Canada and later DEW lines of radar stations looking for Soviet bombers and ICBM’s. This was an Air Force responsibility, but it was the Army Corp of Engineers providing the infrastructure development for these sites, hence why SL-1 was under the auspices of the US Army.
          1. It probably was in some way – with plenty of safety refinements. Its design was administered by same unit of the Army, the Army Nuclear Power Program. Not sure if PM-2A was a BW reactor or not, which SL-1 was.
            It might have had more in common with the earlier SM-1 reactor at Belvoir, as it was manufactured by the same company, the American Locomotive Company. Plus the “P” for “portable(“S” for “stationary”?) and the “M”… which could mean anything considering how mad the Army and other services are for giving things the “M” designation, sometimes in duplicate with other things.
    2. Back then the forces were all bitter rivals for funding and toys and didn’t talk to each other let alone share things.
      Just look at the mess they got in with every branch wanting their own nukes and strike plans and not sharing with the others. When someone eventually got them together in a room to talk about it some of their plans involved the navy turning up to nuke something just as the air force were dropping a brace of nukes over their heads.
      (The book is Command & Control by Eric Schlosser if you want the full clown show – it’s excellently written)
      1. Yes, great book.
        “every branch wanting their own nukes”
        The Atomic Cannon – only useful if there was total air superiority allowing it to be set up which took much longer than the flight time to it of an aircraft starting out well beyond its maximum range, enemy artillery taking even less time. In that case, why not just use an air dropped nuke… dropped by the Air Force. Some humorous anecdotes online from crew members about trying to turn the lengthy monster around German village street corners and move across muddy fields.
  2. “But one incident that you have probably never heard of”
    Maybe I’m the exception, but to me SL-1 is one of the classic and most popular nuclear accident stories because of the “pinned to ceiling” part.
    1. Yeah I would say it’s one of the five most famous nuclear accidents: Chernobyl, Fukushima, Three Mile Island, Demon Core, SL-1.
      Chernobyl is the undisputed king and Fukushima was more recent so those two top the list. The Demon Core and SL-1 make for better stories thanks to the few number of people involved. It’s easier to relate the human element. Three Mile Island got a lot of media coverage and again was more recent.
    2. Thank you – I knew of this one before too and was kinda annoyed that the article is titled
      and mentions this in the 3rd text block
      But one incident that you have probably never heard of took three lives as a direct result of the reactor.[1]
      but only mentions the key memory trigger (at least for me) after the half way point.
      — I had to skim half the damn article to be sure it was about one of the nuclear incidents I already knew about. :-/
      I’m betting at least 1/3rd of HaD readers knew about it already…
      [1] “took three lives as a direct result of the reactor.” ??? of the reactor?? Doing what!
      Is this a legitimate sentence in English? Sounds almost like gibberish to me.
      An incident took three lives as a result of the reactor????
  3. While I find these Hackaday articles about little-known nuclear accidents fascinating, retelling stories from the Cold War deserve to be kept in perspective, and not used for political ends. We are soon-ish likely to see a renaissance of the nuclear power industry, which has been a long time in coming, and is certainly one of the “greenest” forms of 24/7 electricity generation. Modern nuclear energy technologies have made great strides on the safety front, for example pebble-bed designs have been tested to be “meltdown proof.” It is true that no one really solved the problem of storing spent fuel after the State of Nevada proclaimed NIMBY, and to be fair, “please don’t transport spent fuel on trains that pass through our cities” is kinda hard to argue with, but where there’s a will, there’s a way. I’m sure there is a solution out there somewhere. The U.S.A. is a very big place.
    1. certainly one of the “greenest” forms of 24/7 electricity generation
      Except to produce 1 kg of enriched uranium you need amount of electricity equivalent to burning of 1400 tons of brown coal. Not so green anymore huh? After enriching you are also left with tons of depleted uranium which causes cancer in birds, animals and people. If you don’t believe compare number of veterans with cancer from landing in Normandy (WW2) and and in Iraq after 2003 Operation Iraqi Freedom where US Army used DU bullets in tanks, planes and rifles.
      1. That sounds like an argument for natural uranium reactors. Gotta get rid of all that awful cancerous heavy metal by transmuting it into safer elements. ;)
        Also, why are you running your centrifuges on brown coal if you have nuclear reactors? The important thing is that enriching 1 kg of uranium takes considerably less power than fissioning 1 kg of enriched uranium puts out.
      2. Good point, but you could get the electricity from solar or wind, then you won’t have to burn coal.
        You can also mitigate the negative effects of depleted Uranium by not firing lumps of it at people.
        Was there anything else?
          1. Ridiculous, wind and solar power are intermittent at best. Solar power is useless for 3 months in the subarctic regions, as an added bonus, when it gets real cold, its never windy. Most houses these days cant maintain heat without electricity. The only things that works reliably are fossil fuels and nuclear power. So yeah, solar power and wind is an alternative for some places on the earth, but most certainly not usable all over the earth.
      3. Good thing that kilo of enriched uranium holds the equivalent of 8000-9000 tons of brown coal. Maybe we could use that uranium to generate electricity to enrich more uranium and take the majority for other uses? Another crazy thought, ignoring how unscientific comparing cancer rates some 59 years apart is, we could perhaps bury the depleted uranium or use it industrially, rather than exploding it.
          1. You could do that but that would generate transuranics which can be quite nasty if not properly contained. It’s a great idea from an efficiency standpoint but, as far as reducing risk, not as helpful.
            Consider that the uranium came from a mine so putting the depleted uranium back where it came from (in the right form) essentially returns the status quo.
          2. All reactors are “breeder” reactors to some degree. Normally they generate about 30% more fuel out of the loading by transmuting the depleted uranium in the mix. After all, highly enriched uranium would be too “hot” to load in so it is rather diluted.
            That’s also why we can recycle the fuel and return it to use.
  4. Timely article, to see today’s news in Indiana pushing for a mini-nuke for construction. Rendering displayed, it looks like an upside down toilet bowel.
    Heating was of course for those under the ice compounds being built way up north back then, that won’t be possible much longer.
  5. “small nuclear reactors to both heat sites in cold climates and generate electricity when in remote locations or in, as they like to call it, denied areas.”
    The writer is misusing a technical term and does not know what a “denied area” is. For example, Pyongyang is a denied area. For a long time mainland China was a “denied area”.
  6. How about a nuclear site that had not one, two, three, but four accidents (and maybe more that went unreported). Most people didn’t even know it existed yet there were 10 reactors and it was just on edge of Los Angeles. Santa Susana Field Laboratory.
    1. From wikipedia “Experts have said that there is insufficient evidence to identify an explicit link between cancer rates and radioactive contamination in the area.”
      And my favorite part is that in “1996, The Boeing Company became the primary owner and operator of the Santa Susana Field Laboratory and later closed the site”. When the site is so bad that Boeing shuts it down, you know it has to be really really really really really bad.
  7. This must be the source of the story that circulated in the Nuclear Navy about a Navy test reactor in Idaho (Where I think Rickover built the prototype reactor for Nautilus) with basically the same story except it always claimed they were doing experimental “rod pulls”. And it ends with the reactor permanently sealed and the bodies are inside and can’t decay because all the bacteria are dead.
  8. The major sin of nuclear power is clearly not its fatality rate (ludicrously low per kwh) or its pollution (mostly exists in cartoon form on The Simpsons) but the bare fact that it provides a highly viable solution to a problem that an extreme number of overproduced managerial types make their living off organizing activism around.
Leave a Reply to ialonepossessthetruthCancel reply
