We suspect kids today — and some adults — are confused about phone terminology. In today’s world, “hanging up” and “dialing,” for example, are abstract words without the physical reference that older people remember. But some people have a soft spot for the old rotary dial phones, including [Stavros], who wired a rotary phone to his computer for use on online meetings. Check out the video below.
He took an old rotary phone and wanted to program a Raspberry Pi Zero to act as a sound card and a keyboard. That way, he could connect to the meeting by picking up the handset and disconnect by hanging up. He also planned to read the dial and convert that into keyboard input.
If that sounds like a big project, it’s because it is. [Stavros] decided to use Claude Opus 4.1 to write the code for him, but was stymied by the $200/month price tag. So he wrote some code to send queries on a pay-as-you-go plan. After $50 was spent, the code was in worse shape than the first version. So much for vibe coding.
Plan B was — his words, not ours — shameful. He used a cheap USB sound card, an RP2040 to act like the keyboard, and a hub to make it simple to connect. Cases were removed, and boards were integrated into the phone to make a working project.
We do appreciate that [Stavros] tries not to irreversibly damage the old gear when he makes a mod like this. He uses a 3D printed connector to replace the old press-fit connections on the phone’s PCB, and it is all highly reversible.
While Claude didn’t help the development much, perhaps [Stavros] can use the phone to talk to Claude. We’ve seen a number of rotary phone hacks over the years.
I have long had a rotary phone on my desk and during covid teams calls, often people would get a phone call and “needed to pick that up”. As a response, I always picked up the handset of my phone. Hillarity ensued.
He could have saved himself a lot of trouble, and just picked up an ATA from Grandstream for about $50.
If he wanted to use it as a headset on the computer, an ATA is much more complicated to use.
A lot of ATAs don’t put out enough power to drive a real ringer.
“That image is actually not a photo of the phone, but ChatGPT’s best attempt at one, because I’m too lazy to try to find where I put the phone to take a photo of it.”
Yeah, that guy has some wild takes/attitudes.
“Rest assured, though, the image is almost exactly what the phone looks like, except with a bit more 8 and a bit less 3.”
Been using old phones for years, scored a PBX from an upgrade and used VoIP ATA adapter’s to supply dial-tone. Have an assortment of rotary, dtmf, and PBX multi line phones.
