Possibly-Smallest ESP32 Board Uses Smallest-Footprint Parts
Whenever there’s a superlative involved, you know that degree of optimization has to leave something else on the table. In the case of [PegorK]’s f32, the smallest ESP32 dev board we’ve seen, the cost of miniaturization is GPIO.
There’s only one GPIO pin broken out, and it’s pre-wired to an LED. That’s the bad news, and depending on what you want an ESP32 for, it might not phase you at all. What is impressive here, if not the number of I/O pins, is the size of the board: at 9.85 mm x 8.45 mm barely overhangs the USB-C socket that takes up one side of the board.
Pegor provides this helpful image in the readme so you know what you’re getting into with the 01005 resistors.
In order to get the ESP32-C3FH4 onto such a tiny board, all of the other support hardware had to be the smallest possible sizes– including resistors in 01005. If you don’t speak SMD, one could read that number code as “oh god too small” — at 0.4 mm x 0.2 mm it’s as minuscule as you’ll find– and [Pegor] hand soldered them.
OK, he did use a hot plate for the final step, but he did tin the pads manually with a soldering iron, which is still impressive. Most of us probably would have taken PCBWay up on their offer of assembly services, but not [Pegor]. Apparently part of the reason for this project was that he was looking for an excuse to use the really small footprint components.
Aside from leaving out GPIO and needing too-small SMD components, [Pegor] admits that pesky little details like antenna matching circuits and decoupling capacitors had to get cut to make the tiny footprint, so this board might be more of a stunt than anything practical. So what can you do with the smallest ESP32 board? Well, [Pegor] put up a basic web interface up to get you started blinking the built-in LED; after that, it’s up to you. Perhaps you might fancy a teeny-tiny minecraft server? If you can stand to increase the volume a little bit, we’ve seen how to hack a C3 for much better wifi performance.
Thanks to [Pegor] for the tip, and remember– submit your projects, big or small, we read ’em all!
20 thoughts on “Possibly-Smallest ESP32 Board Uses Smallest-Footprint Parts
    1. I recently hand soldered some 01005 [mm] diodes. I thought I got an empty cut of tape until I pulled out the microscope. It took a while, and luckily they included 8 extras on the cut tape (on purpose?). My biggest problem was the pads on the bottom of the silicon kept disappearing. I didn’t have a proper hot air station at the time and the board was too big for my hotplate. I also had to sharpen the end of my tweezers with a file to be able to pick them up. I don’t really recommend this method for anyone unless you have no other choice.
      1. You’re an engineering masochistic. Hand soldering things smaller than grain of salt can be extremely painful and agrivating. One sneeze and you lost $0,03 worth of parts that hadn’t been soldered in yet
        1. Back in the late 70s the prevailing comment about miniaturisation was that package sizes were mostly constrained by the elephantine proportions of the human hand. Now we’re seeing that actually demonstrated
  1. Make the unit TALLER. Add another layer so the bottom layer is a bga. We’ve all seen jtag connections that the spring pins push on. Make the solder pads available for the thin wire we used to get from radio shack (wire wrap super thin stuff). Doing this would give you the ability for all io.
  2. I have trouble , how run any program from linux
    Connected to ESP32-C3 on /dev/ttyACM0:
    Chip type: ESP32-C3 (QFN32) (revision v0.4)
    Features: Wi-Fi, BT 5 (LE), Single Core, 160MHz, Embedded Flash 4MB (XMC)
    Crystal frequency: 40MHz
    USB mode: USB-Serial/JTAG
    MAC: 10:b4:1d:10:30:2c
    Stub flasher running.
    Warning: ESP32-C3 has no chip ID. Reading MAC address instead.
    Hard resetting via RTS pin…
Leave a Reply to cyanicCancel reply
