Bridging RTL-433 To Home Assistant
If you’ve got an RTL-SDR compatible receiver, you’ve probably used it for picking up signals from all kinds of weird things. Now, [Jaron McDaniel] has built a tool to integrate many such devices into the world of Home Assistant.
It’s called RTL-HAOS, and it’s intended to act as a bridge. Whatever you can pick up using the RTL_433 tool, you can set up with Home Assistant using RTL-HAOS. If you’re unfamiliar with RTL_433, it’s a multitalented data receiver for picking up all sorts of stuff on a range of bands using RTL-SDR receivers, as well as a range of other hardware. While it’s most closely associated with products that communicate in the 433 MHz band, it can also work with products that talk in 868 MHz, 315 MHz, 345 MHz, and 915 MHz, assuming your hardware supports it. Out of the box, it’s capable of working with everything from keyless entry systems to thermostats, weather stations, and energy monitors. You can even use it to listen to the tire pressure monitors in your Fiat Abarth 124 Spider, if you’re so inclined.
[Jaron’s] tool integrates these devices nicely into Home Assistant, where they’ll appear automatically thanks to MQTT discovery. It also offers nice signal metrics like RSSI and SNR, so you can determine whether a given link is stable. You can even use multiple RTL-SDR dongles if you’re so inclined. If you’re eager to pull some existing environmental sensors into your smart home, this may prove a very easy way to do it.
The cool thing about Home Assistant is that hackers are always working to integrate more gear into the ecosystem. Oftentimes, they’re far faster and more efficient at doing this than big-name corporations. Meanwhile, if you’re working on your own hacks for this popular smart home platform, we’d probably like to know about it. Be sure to hit up the tips line in due time.
One thought on “Bridging RTL-433 To Home Assistant
  1. I start dabbling with Home Assistant and lo, a hackaday article on it!
    I do think 433MHz/868MHz ASK/OOK sensors and devices are cool but I honestly don’t like the idea of keeping an RTL-SDR connected and running all the time. It gets concerningly warm. Plus most 433MHz et al devices are Chinese abandonware. No documentation, nothing.
    I recently stumbled upon a BLE advertising protocol called “BTHome”. Its a really nice protocol to use if you just want to integrate your BLE sensor/device into home assistant but don’t want to write an entire integration. Just by making the advert format according to their spec, you can make it instantly discover-able with Home Assistant. The only downside is, its unidirectional. But that’s also true with 433MHz sensors, so apples to apples
Leave a Reply to shinsukkeCancel reply
