Reverse-Engineering The Intel 8087 Stack Circuitry
Although something that’s taken for granted these days, the ability to perform floating-point operations in hardware was, for the longest time, something reserved for people with big wallets. This began to change around the time that Intel released the 8087 FPU coprocessor in 1980, featuring hardware support for floating-point arithmetic at a blistering 50 KFLOPS. Notably, the 8087 uses a stack-based architecture, a major departure from existing FPUs. Recently [Ken Shirriff] took a literal closer look at this stack circuitry to see what it looks like and how it works.
Nearly half of the 8087’s die is taken up by the microcode frontend and bus controller, with a block containing constants like π alongside the FP calculation-processing datapath section taking up much of the rest. Nestled along the side are the eight registers and the stack controller. At 80 bits per FP number, the required registers and related were pretty sizeable for the era, especially when you consider that the roughly 60,000 transistors in the 8087 were paired alongside the 29,000 transistors in the 16-bit 8086.
Each of the 8087’s registers is selected by the decoded instructions via a lot of wiring that can still be fairly easily traced despite the FPU’s die being larger than the CPU it accompanied. As for the unique stack-based register approach, this turned out to be mostly a hindrance, and the reason why the x87 FP instructions in the x86 ISA are still quite maligned today. Yet with careful use, providing a big boost over traditional code, this made it a success by that benchmark, even if MMX, SSE, and others reverted to a stackless design.
3 thoughts on “Reverse-Engineering The Intel 8087 Stack Circuitry
  1. “Notably, the 8087 uses a stack-based architecture, a major departure from existing FPUs.” AMD9511, 1977 Integer and 32 bit floating point, trig functions, etc. A stack made it easy to do chained operations to make something like multiply complex numbers. 2MHz $175, 4MHz $350 in 1977 dollars IIRC.
  2. The 8087 was tricky to program in assembler, but using the manual, I was able to code one of the fastest Mandelbrot fractal generators all in the 8087’s stack (and then driving the EGA 640×350 display). Being familiar with RPN on HP calculators helped !
    1. I did a FFT routine using the stack, some reuse of arguments was there, and also thanks using HP’s RPN calculators. That was on a 386sx/387 pair.
Leave a Reply to Charles SpringerCancel reply
