Printing In Metal With DIY SLM
A bed of metal powder is visible through a green-tinted window. A fused metal pattern, roughly square, is visible, with one corner glowing white and throwing up sparks.
An accessible 3D printer for metals has been the holy grail of amateur printer builders since at least the beginning of the RepRap project, but as tends to be the case with holy grails, it’s proven stubbornly elusive. If you have the resources to build it, though, it’s possible to replicate the professional approach with a selective laser melting (SLM) printer, such as the one [Travis Mitchell] built (this is a playlist of nine videos, but if you want to see the final results, the last video is embedded below).
Most of the playlist shows the process of physically constructing the machine, with only the last two videos getting into testing. The heart of the printer is a 500 Watt fiber laser and a galvo scan head, which account for most of the cost of the final machine. The print chamber has to be purged of oxygen with shielding gas, so [Travis] minimized the volume to reduce the amount of argon needed. The scan head therefore isn’t located in the chamber, but shines down into it through a window in the chamber’s roof. A set of repurposed industrial servo motors raises and lowers the two pistons which form the build plate and powder dispenser, and another servo drives the recoater blade which smooths on another layer of metal powder after each layer.
As with any 3D printer, getting good first-layer adhesion proved troublesome, since too much power caused the powder to melt and clump together, and too little could result in incomplete fusion. Making sure the laser was in focus improved things significantly, though heat management and consequent warping remained a challenge. The recoater blade was originally made out of printed plastic, with a silicone cord along the edge. Scraping along hot fused metal in the early tests damaged it, so [Travis] replaced it with a stainless steel blade, which gave much more consistent performance. The final results looked extremely promising, though [Travis] notes that there is still room for redesign and improvement.
This printer joins the very few other DIY SLM machines we’ve seen, though there is an amazingly broad range of other creative ideas for homemade metal printers, from electrochemical printers to those that use precise powder placement.
5 thoughts on “Printing In Metal With DIY SLM
  1. There are a number of commercial SLM manufacturers that use 250W fiber lasers in at least one of their systems, Mlab, 2Ccreate, Realizer, and Xact to name a few.
    You can get a 300W fiber laser engraver from US stock off ebay for $5500, about half what his 500w setup cost him.
    Im sure you could shave a few thousand off other portions of his build as well if you were budgetarily inclined.
    Skipping the oxygen analyzer, hepa recirculation system, and just relying on an argon purge chamber could shave close to another $10k from the $24k BOM.
    Not downing this effort, its very impressive. But Im betting you could get a pretty solid system setup ~$10k.
    1. a raycus 500w fiber laser measures 502755254mm (~20x30x10in) and weighs 70kg. (154lb)
      Hardly enormous.
      Induction lacks the ability to precisely focus its effect the way a laser does.
Leave a Reply to BenCancel reply
