Illustrated Kristina with an IBM Model M keyboard floating between her hands.
Keebin’ With Kristina: The One With The Batwing Typewriter
[Alex] of YouTube channel [EastMakes] wrote into tell me about his fantastic QWERTY ‘hexpansion’ board for the 2024 EMF Tildagon badge, and [Alex], I’m super glad you did. The system works!
Let’s back up a bit. Essentially, the idea is to have a badge that can be used beyond a single camp, with the creation of expansion boards being the other main attraction. Our own [Jenny List] covered the badge in detail back in June 2024 when she got her hands on one.
A pair of hands holds the 2024 EMF Tildagon badge with a QWERTY keyboard Hexpansion built by [EastMakes].
Image by [EastMakes] via YouTube
[Alex] started by importing the Tildagon into Fusion360 and designing a way for the keyboard to attach to it physically. He then modeled the keyboard after the Blackberry types that can be found on Ali using the official EMF buttons established in earlier badges.
This QWERTY hexpansion is based on the RP2040, which is soldered around back and visible through the 3D-printed backplate. In order for the 90°-oriented board to align with the… not-90° connector, [Alex] built a little meander into the PCB.
The default OS on the Tildagon doesn’t know natively what to do with the serial messages from the keyboard, so [Alex] wrote an application that reads them in and decodes them. Be sure to check out the build and walk-through video after the break.
Continue reading “Keebin’ With Kristina: The One With The Batwing Typewriter”
