If you do a lot of one-off parts on your CNC machine you’ll know setup is the worst part of the process. Usually you’re using scrap material, you have to figure out how you’re going to clamp it, make sure the the piece is big enough to use, etc etc. Wouldn’t it be nice to just throw the material on the bed and start machining? Well, with a vacuum table as nice as this, you pretty much can!
[Jack Black] has an awesome CNC machine. As he’s been expanding his prototyping abilities, he decided he needed a better way of securing work pieces for machining, so he machined a two-piece aluminum vacuum table.
Continue reading “Professional CNC Vacuum Table Holds Workpieces With Ease”
