Like many stories, this one started on the roof. This particular roof is located in Michigan and keeps the rain and snow off of the i3Detroit hackerspace. Being an old industrial building, things up on the roof can start getting creaky, and when an almighty screech started coming from one of the rooftop vents as it swiveled in the wind, Nate, one of the group’s coordinators, knew it was time to do something about it.
Previous attempts to silence the banshee with the usual libations had failed, so Nate climbed up to effect a proper repair with real bearings. He dug into the unit, measured for the bearing, and came down to order the correct items. That’s when it struck him: How many should I order? After all, bearings are useful devices, not just to repair a wonky vent but especially handy in a hackerspace, where they can be put to all sorts of uses. Would extra bearings be put to good use, or would they just sit on a shelf gathering dust?
That’s when Nate dropped us a line and asked a question that raises some interesting possibilities, and one which we couldn’t answer offhand: Is there a readily accessible online library of common mechanical parts?
Continue reading “Ask Hackaday: Is There A Common Mechanical Parts Library?”
