Flexible circuits and wearables seem to be all the rage these days. We’ve got conductive paint, glue, and even thread. So how about conductive silicone? Well, as it turns out — it’s not that hard to make.
[Andrew Quitmeyer] has been researching flexible circuits for a while now, and recently stumbled upon an expired patent for flexible ignition cables, using carbon fibers mixed with a conductive silicone. He started playing around with it, and discovered that by dissolving pieces of carbon fiber in rubbing alcohol, letting it dry, and then mixing it into a 2-part silicone you get pretty good electrical conductivity. In fact, in the range of 40-150ohms, which is actually pretty darn impressive!
Continue reading “Conductive Silicone Makes Flexible Circuits”
