Because surplus LED panels from an early 1990s supercomputer is a completely reasonable thing to own, [William Dillon] set to work displaying them on his wall.
The LED panels came from a surplus CM-5 Connection Machine, best known from it’s role as the mainframe in Jurassic Park (only an empty case with LED panels were used in the movie). When not on Isla Nublar, the Connection Machine was a fabulous piece of engineering from the 1980s Artificial Intelligence revival. With some machines having 65,536 processors, it was used for AI research using Lisp (although we were never very good at Lisp.
[William] built a wooden frame out of 1×2 inch maple and installed an X10 module behind the panels as a remote switch. The panels themselves aren’t controlled by a computer, so the only thing left to do was to mount the power supplies. It’s impressive to see the massively over-engineered power supplies that were designed to source 5V @ 30A when the panels only draw 7 Amps. [William] says it was a design feature of the Connection Machine to spare no expense.
[William]’s next plan is to reverse engineer the panels to display custom messages, and we can’t wait to see what he comes up with. We can’t explain why, but we really want to build one of these panels. Check out the pictures of [William] decommissioning the CM-5.
