Hackaday alum [Caleb Kraft] has been busy working on control modifications for gamers with disabilities. His latest release is a modular system of thumbstick extensions for the Xbox 360 and Xbox One. Since starting The Controller Project, one of [Caleb’s] goals has been to create a system to facilitate the use of analog thumbsticks. Now that he has a few controller mods under his belt, [Caleb] decided to attack the problem head on. Rather than print a custom adapter for each gamer, he’s created a set of 3D printed extensions which can be mixed and matched to produce the perfect controller mod.
The base fits perfectly over the Xbox thumbstick. The fit is tight enough to stand up to some serious gaming, but can be easily removed with no permanent change to the controller. Extensions stack on top of the base to build up a large easy to grasp stick. There are straight and angled extensions to accommodate specific disabilities. The stick can be capped off with a rounded tip or an easy to grip knob. The exertions are designed to fit together loosely for testing. Once the gamer finds a perfect stack of extensions, a bit of glue locks everything together.
The best part is that [Caleb] has released the files for the entire system. 3D printers are becoming common enough that nearly everyone has access to a printer, or knows someone who does. Click past the break to see [Caleb] demonstrate the modular thumbstick extension system!
Continue reading “A Modular Thumbstick Extension For Gamers With Disabilities”
