[Daniel ] sent in this one, from an O’Reilly book, it’s older but the results are just stunning. The iPod dock has been done countless times, but the really interesting part is the custom dash molding technique. The cradle was mocked up with clay on the original piece, then a silicon mold was cast from the mock up. After that, the entire piece was re-created inside the mold. After some dremel work and a bit of sanding, it came out beautifully. It looks like a great way to make custom LCD/GPS dash inserts.
