A bug was recently fix in Signal that allowed a caller to force a call connection without any user interaction on the receiving side. We’ve seen this sort of problem in other chat applications, most recently the Zoom debacle.
The Signal client uses the same function to connect an outgoing call as an incoming call. This bit of code re-use allows a malicious client to initiate a call, and then send the “Accept Call” message. Because of the code re-use, this message triggers the same code as the accept call button on the receiving side. It’s as if the attacker uses reverse psychology to trick the other client into connecting.
It seems this bug only affected the Android client, and didn’t trigger a video call. It’s unclear whether the bug was discovered and exploited before it was fixed, but now that it has been announced, be sure to get Signal up to date. Continue reading “This Week In Security: Signal, WhatsApp, Oauth Fishing, And More State-Sponsored Attacks”
