ATMega328 3D!
Small OLED displays are inexpensive these days–cheap enough that pairing them with an 8-bit micro is economically feasible. But what can you do with a tiny display and not-entirely-powerful processor? If you are [ttsiodras] you can do a real time 3D rendering. You can see the results in the video below. Not bad for an 8-bit, 8 MHz processor.
The code is a “points-only” renderer. The design drives the OLED over the SPI pins and also outputs frame per second information via the serial port.
Continue reading “ATMega328 3D!”
