Today the newly-released Nintendo Game & Watch can play DOOM. Sure, there are caveats…this is a watered down version due to the restraints of the hardware itself. But the important thing is that this shows the hardware has been fully owned. This is code written to replace the firmware that ships on the STM32 within, and that makes this a gorgeous little hardware platform that is completely open to homebrew hacking.
Honestly, you had to assume this was going to happen pretty quickly considering the effort being thrown into it. We first reported on Tuesday that the EEPROM memory which stores the ROMs on the Game and Watch had been decoded. Shortly after that was published, [stacksmashing] and [Konrad Beckmann] were showing test patterns on the display and mentioning the audio was working as well. Turns out they were able to dump the stock firmware despite the chip being security locked.
We’ll have to wait for more details on exactly how to dump firmware, but [stacksmashing] drops enough of a mention in the video below to confirm the obvious. A common approach to dumping code from a locked microcontroller is to find a vulnerability that grants execution of custom code. Being able to run just a few lines of your own code is enough set up something as simple as looping through all internal flash memory addresses and dumping them over a few GPIO pins. In this case our two heroes discovered some ARM code was being loaded from the EEPROM onto the STM32, and managed to inject their own directives to perform the dump. They have promised full details soon.
What we have today is a pretty tricky hack not just to load code, but to get DOOM to run on meager hardware specs. Notably, 128 k of SRAM and 1.3 MB of external RAM. There’s also a bottleneck with the 1.1 MB of FLASH for storing game files. The textures were stripped down, and memory allocation was rewritten, but the proof of concept is there and the game runs. Homebrew, here we come!
Continue reading “DOOM Running On The Nintendo Game & Watch”
