[Old Alaska] had a problem. He needed a second remote for his apartment garage door, but was quoted a fee in the hundreds of dollars for the trouble of sourcing and programming another unit. Realizing this was a rip-off given the cheap hardware involved, he decided to whip up his own sneaky solution instead.
It’s a simple hack, cheap and functional. An RF-activated relay with two remotes was sourced online for the princely sum of $8. [Old Alaska] then headed down to the equipment cabinet in the garage, opening the lock with the side of his own car key. He then wired the relay in parallel with the existing manual pushbutton for activating the garage door.
Sometimes, a hack doesn’t have to be complicated to be useful. Many of us might have jumped straight to trying to capture and emulate the existing remote’s radio signals. There was really no need. With physical access, [Old Alaska] was able to simply wire in his own remote entry setup himself.
We’ve seen similar hacks before, albeit achieved with SIGINT methods instead. Video after the break.
Continue reading “Hacking An Apartment Garage Door With New Remotes”
