A photo of two magnetic bubble memories installed in a circuit board
Scott Baker’s Magnetic Bubble Memory Mega-Post
Over on his blog our hacker [Scott Baker] has a Magnetic Bubble Memory Mega-Post.
If you haven’t heard of magnetic bubble memory before it’s basically obsolete nonvolatile memory. Since the 1970s when it was introduced this type of memory has been outperformed in every dimension including durability, reliability, price, density, performance, and so on. For any given application of bubble memory you will be able to find an alternative technology which is better in many ways. Except if you want some old tech to geek out over, in that case magnetic bubble memory is for you!
Continue reading “Scott Baker’s Magnetic Bubble Memory Mega-Post”
