[Gordon Johnson] recently completed part 1 of his toaster computer project. He used a standard four slot toaster as the enclosure and cut holes for access to the ports and a wireless antenna. While the specifications of the components used are not mentioned, the build is well documented on his site, complete with lots of pictures and a video. While he used a traditional fan based cooling method for part 1 of the build, he plans on using a special cooling method for part 2 that uses aluminum and mineral oil to create a thermoelectric cooling effect.
