A Versatile PDP-11/70 Emulator
The PDP-11 was a 16-bit minicomputer that was very influential in its time. That’s what inspired [vanheusden] to start working on an emulator for the machine in 2018, which has since been developed to run on a wide variety of platforms.
The emulator, named “Kek,” is quite capable, able to run Unix 5 up to an d including Unix 7 in multi-user mode, along with BSD 2.11 Unix depending on what it’s running on. It also supports classic hardware like RK05, RL02, RP06, and RP07 disks, the KW11-L line time clock, and the DC-11 serial line interface. The emulator can also run on a wide variety of platforms. It’s possible to run it on a standard Linux machine if so desired, or you can run it on BSD, MacOS, or Windows if so desired. Beyond that, you can even get it going on a Teensy 4.1 or an ESP32 if that’s more your jam. Modern microcontrollers are just that powerful that emulating a PDP-11/70 just isn’t a challenge anymore.
We love seeing old machines emulated and brought back to life. It’s funny to see how often it’s done on microcontrollers instead of full-scale PCs these days, too. Video after the break.
Continue reading “A Versatile PDP-11/70 Emulator” →
