Apparently our Russian brethren have some issues ordering things online. Their shipping solution? A bit of remote social engineering. Thanks to the nature of Russian addresses – that is, the language is pretty easy to recognize – they’ve found that putting down their address in Russia along with a Canadian zip code will usually result in the package being forwarded along thanks to the thoughtful Canadian postal workers. Thanks [Jock]
Social engineering not your thing? OK, well here’s a few extra hacks to chew on. [Sam] thinks you should wrap your electronics in a condom to keep em dry. If you’re in NY, you might want to check out the circuit bending festival. Oh, and if you’ve had your head in the sand, you might have missed the steam powered R2D2.
