When I was in the 4th grade our teacher announced that we had a special guest visiting us from somewhere “Far, far away…” As we piled out of the classroom and into to the courtyard, my jaw hit the floor – It was R2D2! The droid started to move around, and made all the noises like the movie. I couldn’t believe what I was seeing. R2D2 was real, and he was right in front of me! (My young mind made the conclusion that if R2D2 was real, then all of Star Wars was real.) I had to turn around to see my friends’ reactions. Unfortunately, it’s at that moment, I saw a middle-aged man, holding a RC transmitter, with antenna extended, standing in the background operating the controls. Sigh. R2 wasn’t real – it’s just a remote-controlled robot. My dreams of becoming a Jedi were forever crushed.
[Chris James] of the R2 Builders Club has been working hard to make a pair of “Stealth RC” controllers to help keep the magic of R2D2 intact. These dual joystick, 3D printed, hand-held units can be easily hidden in the palm of your hand, or the front pockets of a loose jacket while you operate them. Loaded with features, these tiny controllers use XBee radios to talk to a receiver and custom PCB inside the droid, that in turn, can then control dozens of servos, motors, sound playback and more. Because some R2D2 builds will have dozens and dozens of functions, rather than have a button for each one, [Chris] has programmed in gesture controls in to the unit, so that two controllers and can control several dozen preprogrammed actions. [Chris] hasn’t finalized the design just yet – he still calls it a “beta” build, but so far his documentation is outstanding (PDF) – some of the best we’ve seen.
You can learn more about the R2 Builders Club and the controllers in the video after the break
Continue reading “These Are The Droid Controllers You’ve Been Looking For”
