This image contains a hidden audio track which you’re very familiar with. Well, it used to. We’d bet we messed up the careful encoding that [Chris McKenzie] used to hide data within an image when we resized the original.
He’s using a method called Steganography to hide a message in plain sight. Since digital images use millions of colors, you can mess with that color data just a bit and the eye will not really be able to pick up any difference. Each pixel has had the eight least significant bits swapped out for the data [Chris] is hiding. Since the image uses 24-bit color, the largest possible change (going from 0 to 255) in those bottom eight bits will only result in a color change of about 0.15%. And that’s only for one pixel; in most cases the change will be much less.
He shows his work, both decoding and encoding using Ruby, and even provides a one-liner which lets you playback the audio without downloading anything (just make sure you’ve got all of the dependencies installed). Never gonna give, you, up…
[via Reddit]
