Parts: Analog Distance Sensors (Sharp GP2D12/2Y0A02)
[youtube=http://www.youtube.com/watch?v=iGiRK0vmcUw]
Sharp GP2D12 and 2Y0A02 infrared rangers output a voltage proportionate to the distance of an object from the sensor.  The GPD12 senses objects at a distance of 10-80cm, while the 2Y0A02 has twice the range.
We’ve previously looked at the Sharp GP2Y0D02 digital proximity sensor. It only signals the presence of objects, while the GP2D12 and 2Y0A02 measure distance to them. If you’ve got a GP2YoD02, it might still be possible to tap the analog output. We’ll show you how use these sensors below.
Continue reading “Parts: Analog Distance Sensors (Sharp GP2D12/2Y0A02)”
