Lara Croft On A Microcontroller
Once upon a time, you had to carefully budget your microcontroller’s resources if you wanted to do something as simple as flash a bunch of LEDs. These days, they’re powerful enough to humiliate the game consoles of yesteryear. [alexkid77] demonstrates this well, having the ESP32-P4 run Tomb Raider.
Now, [alexkid77] hasn’t gone so far as to create a PlayStation emulator on the ESP32 or anything quite like that. Instead, this is a port—and not of the original Tomb Raider release, either. [alexkid77] started with OpenLara—the classic game running in an open-source engine. With the ESP32-P4 having two cores running at 400 MHz each, there was plenty of processing power on tap to run the engine with a software renderer at 320×240, which is hardware scaled up to 1024×600 via the Pixel Processing Accelerator (PPA) built into the chip. There’s also stereo audio with an ES8311 codec hooked up, while input is via a USB HID keyboard.
It’s funny to think that it could actually be cheaper and quicker to get Tomb Raider running on an ESP32 and a cheap LCD display versus actually going out to buy a PlayStation and an original game disc. But that’s the way the cookie crumbles in 2026. At least you don’t have to play it on an S3 Verge. Continue reading “Lara Croft On A Microcontroller” →
