With the transition to digital TV, the FCC has abandoned the old analog format. Luckily, you can take advantage of this and set up your own analog TV station. The FCC has a tool on their site to see what channels are open in your area to broadcast in. To broadcast, you need a TV transmitter, but cheap short-range models can be found on eBay or made at home [pdf]. Once you have a transmitter, you can pump in a video source, either your own content or videos from youtube. One group, OMGimontv is showcasing popular youtube clips on channel 14 in New York. On their site, users can vote for what clips they want to see. Although this isn’t as simple as making a radio station, it still has a lot of potential.
[via BoingBoing]
