Art of 3D printer in the middle of printing a Hackaday Jolly Wrencher logo
Improving FDM Filament Drying With A Spot Of Vacuum
Keeping your filament safely away from moisture exposure is one of the most crucial aspects of getting a good 3D print, with equipment like a filament dryer a standard piece of equipment to help drive accumulated moisture out of filament prior to printing or storage. Generally such filament dryers use hot air to accomplish this task over the course of a few hours, but this is not very efficient for a number of reasons. Increasing the vaporization rate of water without significantly more power use should namely be quite straightforward.
The key here is the vapor pressure of a liquid, specifically the point at which it begins to transition between its liquid and gaseous phases, also known as the boiling point. This point is defined by both temperature and atmospheric pressure, with either factor being adjustable. In a pressure cooker this principle is for example used to increase the boiling temperature of water, while for our drying purposes we can instead reduce the pressure in order to lower the boiling point.
Although a lower pressure is naturally more effective, we can investigate the best balance between convenience and effectiveness.
Continue reading “Improving FDM Filament Drying With A Spot Of Vacuum”
