[Garagedeveloper] sent us his custom surveillance system, part 1, part 2, and part 3 after needing a way to find out why some cables at work were becoming unplugged (spoiler, the cleaners were messing up the wiring). At the base of the system is a web cam glued to a stepper motor. However, it gets much more in depth with a web front-end that allows the user to stream the feed and control the position of the stepper. We’re not particularly fond of how many different parts the project takes, while it all could be accomplished under C# with ASP.NET and parallel port library instead of including Arduino and excess code, but to each their own and the project turned out a success anyway.
