Illustrated Kristina with an IBM Model M keyboard floating between her hands.
Keebin’ With Kristina: The One With The Pretty Protoypes
Some like it flat, and there’s nothing wrong with that. What you are looking at is the first prototype of Atlas by [AsicResistor], which is still a work in progress. [AsicResistor] found the Totem to be a bit cramped, so naturally, it was time to design a keyboard from the ground up.
Image by [AsicResistor] via reddit
The case is wood, if that’s not immediately obvious. This fact is easily detectable in the lovely render, but I didn’t want to show you that here.
This travel-friendly keyboard has 34 keys and dual trackpoints, one on each half. If the nubbin isn’t your thing, there’s an optional, oversized trackball, which I would totally opt for. But I would need an 8-ball instead, simply because that’s my number.
A build video is coming at some point, so watch the GitHub, I suppose, or haunt r/ergomechkeyboards.
Flat as it may be, I would totally at least give this keyboard a fair chance. There’s just something about those keycaps, for starters. (Isn’t it always the keycaps with me?) For another, I dig the pinky stagger. I’m not sure that two on each side is nearly enough thumb keys for me, however.
Continue reading “Keebin’ With Kristina: The One With The Pretty Protoypes”
Keebin’ With Kristina: The One With The Keyboard Configurator
Have you ever wished you could experiment with different layouts super easily, just by adding or removing a few switches here and there and printing a new case? Well, [heyisjambo] says that it’s more than possible with menura, the modular keyboard system.
A collage of menura keyboards, which are modular via the VIK standard.
So many lovely options! Image by [heyisjambo] via GitHub
[heyisjambo] is happy with 36 keys, but is reduced-count-curious and wanted a way to explore without a lot of wasted time and PCBs.
At the same time, [heyisjambo] wanted to experiment with split vs. uni-body construction, and especially the different shapes that are possible when tweaking the angle and distance between them.
And as if that weren’t enough, there’s support for [Sadek Baroudi]’s VIK standard for interfacing data between PCBs, which calls for an FPC 12-pin, 0.5 mm pitch connector and allows for ultra-cool magnetic connectors. This way, you can easily add things like displays, trackpads, and trackballs in the between the halves.
Thanks for the tip, [calculus]!
Continue reading “Keebin’ With Kristina: The One With The Keyboard Configurator”
Keebin’ With Kristina: The One With All The Espionage
[Ziddy Makes] describes this cute little guy as a biblically-accurate keyboard. For the unfamiliar, that’s a reference to biblically-accurate angels, which have wings (and sometimes eyes) all over the place. They’re usually pretty scary to behold. Don’t say I didn’t warn you.
A cube keyboard with adorably vibrant pastel keycaps.
Image by [Ziddy Makes] via GitHub
But this? This is the opposite of scary. Sure, there are keys everywhere. But it’s just so darn adorable. You know what? It’s those keycaps.
This 16-key macro cube uses a Pro Micro and a system of PH2 5p ribbon cables to connect the four four-key sisterboards to the main board. A 3D-printed base holds all the boards in place. Out of all the switches in the world, [Ziddy] chose Otemu Blues. Clack!
Although it may take some getting used to, this seems like it would be a fun way to input macros. I can see the case for putting some rubber feet on the bottom, otherwise it might scoot around on the desk. That might be cute, but only the first couple of times, you know?
Continue reading “Keebin’ With Kristina: The One With All The Espionage”
Keebin’ With Kristina: The One With All The LEGO
It seems like mechanical keyboard enthusiasts are more spoiled for choice with each passing day. But as broad as the open source pool has become, there’s still no perfect keyboard for everyone. So, as people innovate toward their own personal endgame peripherals and make them open source, the pool just grows and grows.
Image by [Bo Yao] via Hackaday.IO
This beautiful addition to the glittering pool — [Bo Yao]’s Carpenter Tau keyboard — is meant to provide an elegant option at a particular intersection where no keyboards currently exist — the holy trinity of open source, programmable, and tri-mode connectivity: wired, Bluetooth, and 2.4 GHz.
Come for the lovely wooden everything, and stay for the in-depth logs as [Bo Yao] introduces the project and its roots, reviews various options for the controller, discusses the manufacture of the wooden parts, and creates the schematic for the 61-key version. Don’t want to build one yourself? It’ll be on Crowd Supply soon enough.
Continue reading “Keebin’ With Kristina: The One With All The LEGO”
Keebin’ With Kristina: The One With The Arboreal Keyboards
Well, unfortunately we don’t know much yet about this nice wooden keyboard from [Kelvin Chow], but maybe this inclusion will encourage [Kelvin] to post more about it.
Sure is nice-looking, don’t you think? That’s because there some great details at play here, like the legend-less two-tone keycaps and the neat-o locking box it sits in.
This keyboard is inspired by the Hacoa Ki-board, which uses a singles plank of wood to craft the keycaps. [Kelvin] wanted to try this technique for themselves. Evidently this won’t be the last wooden keyboard, so stay tuned for more over on Hackaday.io.
This isn’t the first dead-tree keyboard we’ve seen around here, either. A while back we saw one with Scrabble tile keycaps, and earlier this year, a nice wooden macro pad.
Continue reading “Keebin’ With Kristina: The One With The Arboreal Keyboards”
Gaming Keyboard Features Incredible Workmanship
Gaming Keyboard in Desk
Hello people, look at your keyboard, now back to this one, now back to your keyboard, now back to us. Sadly, your keyboard isn’t this one, but if you’re handy with wood and metalwork, it could look like this one!
This incredible keyboard was made with the blood, sweat, and tears of [Kurt Plubell], an architectural draftsman. He began a few years ago when he hung up his T-square and started using CAD for his work. His biggest complaint about CAD? Ergonomics! His setup slowly evolved as he was determined to find the most comfortable way to work. First, a keyboard and a trackball. Then, a keyboard, a trackball, and a left-handed mouse. Then, an ergonomic keyboard on a desk mounted tray (and trackball + mouse) — he still wasn’t satisfied. Thus began his journey into a fully customized setup.
He started with the ErgoDox keyboard, which is a two-part ergonomic keyboard. He ordered the aluminum version, which isn’t quite as nicely finished as you would think — but we doubt the manufacturer was expecting its consumers to be taking it apart and integrating it into something else. A lot of sandpaper, die grinding and polishing later, and it had a much nicer finish.
The keyboard was built up using wood and MDF, and finally finished with a very nice wood veneer, giving a very executive finish to the project. He’s integrated four arcade buttons and a Kensington track ball in the very middle — and of course, being a true typist, his keys have no markings.
[via Reddit]
