Maker Faire 2008: ShiftBright RGB LED module
posted May 8th 2008 8:00pm by Eliot Phillipsfiled under: cons, led hacks
We made a point to stop by [garrett]’s booth at Maker Faire to to see what he had been working on. You may remember him from his random caps locker shenanigans. He’s just recently released the ShiftBright RGB LED module which makes it easy to implement a string of individually addressable LEDs. The module is based on the Allegro A6281 3-Channel Constant Current LED Driver. The driver chip is capable of displaying a billion colors using an RGB LED. The 3×3mm package is mounted to the backside of the board while a bright common-anode RGB is mounted to the front. The modules are designed to be daisy chained together and are individually addressed using a serial interface. You can find Arduino example code on the site and more info on how the item was developed. Read on for close up images.
Wow that looks sweet, the kinda thing case mod freaks would kill for on thier pc (I know I would lol).
Posted at 9:09 pm on May 8th, 2008 by Mojo
