Antec Skeleton case
posted Sep 16th 2008 2:10pm by Eliotfiled under: misc hacks, news, pcs hacks
Maybe you saw the previous post and thought, “Well, that’s all well and good, but why is such a stylish case being used to ventilate cat feces?” Antec has heard your cries and has created a computer case with all the lovely curves of a litter box and just as much airflow. The Skeleton case has an open frame design with a 250mm fan on top. You mount the motherboard to a sliding tray. The power supply and hard drives are mounted underneath. It’s an interesting idea and easily replicated, but if cooling had been the goal, it would be a lot more enclosed. You can see the case with components installed on TweakTown.
[via acquire, thanks, xtine]
sounds like a good way to get even more dust / bugs / cat hair in your pc…
