Inexpensive powerful router based robot
posted Oct 7th 2008 10:42am by Caleb Kraftfiled under: classic hacks, robots hacks
[Andrey Mikhalchuk] Has posted some great instructions on how to build an inexpensive router based robot. Starting with a Linksys WRT54GL, he takes us through the process of disassembling and modifying it to directly control servos. He has put together a custom version of OpenWRT Linux that you can download from his site. After testing to make sure everything is functional, he goes through a quick and dirty chassis build. As you can see from the picture above, there are lot of household items thrown in there such as rubber bands and zip ties. After adding a camera mounted on two servos for x y movement, he fine tunes it and lets it go.
This project looks fairly simple, cheap, and fun. It may look familiar as it is very similar to our Wifi Robot post from August.
[thanks Matt]
His site appears to be loading slow, so if anybody’s got a mirror that would be cool.
Just looking at the pic above, I wonder what kind of traction the bot gets on tile floor. It looks like it has grooves cut that would grip carpet good with the cd wheels, but it seems like it still might have a hard time on hard floor.
