Liquid Tree
posted Nov 11th 2008 12:00pm by Kimberly Laufiled under: arduino hacks, home hacks, lifehacks
Liquid Tree is decorative, functional, and green. It’s a liquid feedback display created by [Jia Yi Lin] that is designed to tell you exactly how much water you’re wasting in the shower. Behind the pretty tubes is some interesting hardware. [Lin] used an Arduino board, and based her code off the Unipolar Stepper example. She’s posted her own code and wiring for the project. When hot water is turned on, the motors decrease the amount of liquid in the tubes. This causes the pattern to slowly disappear, indicating water consumed.
[via NOTCOT]
Nice. Now you can waste power while you waste water. ;)
I kid, but I do wonder whether it’s possible to put a small turbine or wheel inline with the water pipe so the circuit is hydropowered. Somewhat similar to stationary cycles that use your pedal power to drive the display.
very cool project, I love unique ways to visualize data.
Posted at 12:16 pm on Nov 11th, 2008 by Jesse
