Parts: 133MHz-16.2kHz Programmable Oscillator (DS1077)
cover
The DS1077 is a 5volt, 133MHz to 16kHz programmable clock source. The internal frequency divider is configured over a simple I2C interface, and the chip requires no external parts. Not bad for under $2. We used the Bus Pirate to test this chip before using it in a project. Grab the datasheet (PDF) and follow along. Continue reading “Parts: 133MHz-16.2kHz Programmable Oscillator (DS1077)”
