[Backroads] has put together this nicely detailed writeup explaining how to make a low cost popup prop. He’s using a single pneumatic valve and a home made PVC piston to raise and lower a scary mask. He’s using an off-the-shelf 110v AC valve controller to control the valve. A flickering light, a “screamer” and a fog machine help fill out the project. The result is quite nice. We would be tempted to put a pressure sensor in front of it to optimize the scare timing.
Subscribe for weekly videos
He should decorate the garbage can.
He doesn’t mention where the compressed air is being supplied from, any ideas?
a compressor :p
