Sound card driven servo motor
posted May 26th 2010 10:00am by Mike Szczysfiled under: pcs hacks
[Darrell] is using a sound card to drive this servo motor. The motor draws power from a cellphone battery with the control signal coming from one of the audio channels. It’s not too surprising that this works since the motor just needs a PWM signal to operate and that’s what is used to create the different frequencies of sound on electronic speakers. We’re not sure what [Darrell's] got planned for this system but he mentions that two servos can be used, one on each audio channel. If you’re not using your sound card this would be a way to stop using the Arduino for that mail checker and just use a little flag attached to a servo. When mail comes in the appropriately engineered sound raises the flag.
Two channels? Why not implement this with a cheapy 7.1 channel card, and get all kinds of little flags? That would be pretty cool.
