Inductive cellphone charging without voiding warranty
[Derek Hughes] wanted to use inductive charging on his cellphone without voiding the warranty. He picked up a Pixi charging backplate meant for a Palm Pre and scavenged the coil and regulator circuitry from it. To make the electrical connection with his HTC HD2 he removed the mini-USB plug from a charging cable and connected it with 30 gauge wire. The whole package will fit beneath the back plate for use with a Touchstone charger (as we’ve seen with the HTC Evo) but there was one problem. The metal backplate from the HD2 interferes with the inductive charging. For now he’s using tape to hold everything together while searching for a plastic case replacement.
He walks you through the hack in the video after the break. We’re usually not worried about voiding warranties, but a phone like this takes a lot of abuse and having warranty protection or even a service agreement isn’t a bad idea.
26 thoughts on “Inductive cellphone charging without voiding warranty
  1. What I don’t get is why they don’t use the same system on cellphones that they use on classical wireless phones in the home, 2 large metal contacts on the bottom and you put it in the stand and it recharges without fiddling with plugs or slotting it into a small connector.
  2. the little microusb board sticking out is… kinda impractical, isnt it? you cant really put that into your pocket or anything…
    and @alfcoder
    where can I get the schematic or guide to make that, thats pretty sick.
  3. I wish I could find some info on that wireless charger. How is a DC current generated? Is there a transformer on the board connected to the induced coil? I’m assuming that an AC current is being induced in the coil, which wouldn’t be able to charge the battery.
    1. DC Power Supplies use step down transformers, rectifiers, filters, regulators.
      To charge a battery you just need a step down transformer and a full wave rectifier. A filter would be nice.
  4. lol.. i had this idea a few weeks back because my nokia el cheapo phone had a flaky unreliable charging connector.
    one thing that might work is some shapelock carefully formed into a copy of the unusable backplate, then if you want mix in some of that “Heat-it-Up” black pigment.
  5. Rough finish, but a good proof the hack is functional. Personally I’d like to see drop in charging bases be made available. Inductive charging is far out, but I wouldn’t want my wallet with numerous magentic strips near them, and I like to keep my wallet where my check book, phone,keys HT, and pocket knife are kept by the door.
  6. Hello there bob,
    Actually there is a small circuit attached to the coil via an f-pcb. It is a relatively straight forward chip-based, surface mount circuit that they conveniently covered in black epoxy.
    I did the same thing to my EVO, although I did mine internally and with a PIXI backcover….guys you can pick up the PIXI back covered at many radioshacks right now for $6 with tax. I really should have bought more of them so that everything could be made inductive!
  7. you know i see this and i was wondering is the battery in this phone internal and not removable. cause otherwise why not buy another battery and just add this to the battery itself. i have about 50 different battery packs that all charge in different ways and built a diy charger for them very crudely. however when i saw afroman’s inductive article i was playing with my Lg Chocolate and did it to a separate battery.
  8. “a Pixi charging backplate meant for a Palm Pre”
    No, it’s a Pixi charging backplate meant for a Palm Pixi. No Pre parts.
    Good work for adding inductive charging, but I would worry about that snagging that little dongle sticking out of the bottom. Even when you get a good plastic back, the cable part sticking out from the bottom will be your weakest link.
    @fartface: Palm did!
  9. Can anyone help me out with figuring out what circuit is required to wire this directly to the battery so the plug does not have to stick out? I am attempting this on my Dell Streak.
    I know the phone wont recognize the charger by going this way, but I would expect I would need some form of power management so as not to overcharge the battery. Or is this already built into the Pre’s induction piggy-back circuitry with the coil?
    I would love to be able to internalize this in a simple way where I wouldn’t have to solder to the PDMI connector on the mainboard.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
