Singing: With Plasma!
While there are many ways to produce audible sound, Plasma Speakers have to be one of the coolest. Usually very complex and expensive, we received a tip for a beginners guide to making one of these impressive novelties. Handily included are a set of schematics (one very simple schematic, the other with a few artistic illustrations). There are also a set of warnings, which include sound advice to mind the heat generated by the MOSFETs, as well as making sure that your input signal isn’t too strong. The finished product is fun to listen to, so be sure to check out the example video after the break.
Comments
  1. grenadier says:
    2 in one day, cool!
  2. DerAxeman says:
    I love the use of a spent .22 shell. I now have a near limitless supply of one component to build this
  3. Hackius says:
    WTF? Copyright notice? I think it’s time someone sued back.
  4. YouTube’s copyright protection is out of control. Who the hell will listen to this video just because of the music? Plasma playback quality is far from good.
  5. yetihehe says:
    Why didn’t he just use some music from jamendo? He would have no problem and the artist would probably thank him ;)
  6. Nomad says:
    Can anyone upload it somewhere else?
    On some not capitalist video hoster?
  7. grenadier says:
    You could always use a proxy…
  8. grenadier says:
    Ok, I submitted a copyright dispute. Hopefully that will help.
  9. Zopieux says:
    I’ve mirrored the video on my web server. You can watch the vid without any restriction at:
    http://repo.zopieux.com/hackaday/plasma.html
    Thanks for the interesting post!
  10. daman says:
    Do these emit xrays? I know crts are capable of it and have built in circuitry to limit exposure.
  11. grenadier says:
    The block was lifted!
    Enjoy the video Germans.
  12. iklln6 says:
    that is the coolest fucking thing i’ve ever seen in my whole life
  13. grenadier says:
    @daman
    No x-rays as there is no vacuum.
    @Zopieux
    Thanks, but I convinced youtube to lift the ban.
  14. Bob says:
    Put an extra winding on the HV transformer and you can get rid of the gate drive transformer and the 10.000µF DC blocking capacitors.
  15. grenadier says:
    I tried that before and it blew up every piece of active silicon on the breadboard.
  16. Girrrrrrr2 says:
    Wow… I was actually thinking of following your first one. But now you just updated it, so now I wont have to have an ice bath to show it off!
  17. Fallen says:
    :D I have the parts to make this. Well I was planning to make some plasma tweeters for a while now. I picked up 2 of the 15kW inverter board from a X-Ray machine a while back, they have 16 800V mosfets on them each. Actually it’s pretty well everything in that circuit except for the driver chip.
    Anyways one quick question/thought. Did you remove the HV diode on the secondary of the flyback transformer? I would imagine if you didn’t it would add quite a bit of distortion to the audio being reproduced. I was planning to go the tesla coil route, but figured it would end up ‘ringing’ which would also ruin the sound quality. I need to find one of the old flybacks without the diode potted inside.
  18. Zopieux says:
    @grenadier
    Yeah, no problem. May be usefull if Youtube goes down :)
  19. grenadier says:
    @Fallen
    AFAIK there is no way to remove that diode so yeah, it’s still in there.
    Do you happen to have the multiplier boards that were in the xray machine? If so I’m very interested in them.
  20. Ugly American says:
    @Fallen
    The drone you hear on Tesla coil audio is caused by the spark gap in the primary circuit which causes a relatively low square wave modulation of the high frequency secondary oscillation.
    To hide the drone, keep the frequency of the ringing up above human hearing and more than 2x the max frequency of the sound you want to reproduce. 48KHz would work well.
  21. MrCung says:
    Daaamn i’d buy this :P Awesome work dude.
  22. Fallen says:
    @Grenadier,
    I still have them, I ‘obtained’ (my manager told me I could keep them) them from one of my employers a few years back. I was working for an OEM in the RMA department, and these came back with some blistering between the fiberglass weave on the PCB. We decided scrapping them was cheaper than reworking(especially since IIRC the multiplier boards they drove got up to 100kV, so it was important that the insulating ability of the PCB wasn’t hindered.).
    Unfortunately I don’t have the multiplier boards. I sure did repair a lot of them though :).
    It was a fairly standard circuit they used, just a cockroft walton(sp?) multiplier, in parallel with a 1W 10MR resistor. There was also a second multiplier on some boards for filiments or something, I can’t remember. Oh and a couple resistors in a voltage divider to monitor the voltage out.
    The boards had slots routed in them between HV parts, and everything was immersed in oil.
    The company they were made for was CPI, but I don’t know the exact product/products it was used in.
    I’m going to hang onto them as I’m a class D nut.
    Honestly the real reason I haven’t went forward with it is ozone production. It’s nasty stuff, and I haven’t figured out a cost effective way of building the tweeters and doing away with ozone production. :) using argon or helium would be way too expensive.
  23. zool says:
    not a very high caliber speaker ;)
    also plasma next to carpet, not a great idea
    but this is pretty cool
  24. grenadier says:
    @Fallen Actually since this one only puts out 10kv there is no ozone!
  25. ejonesss says:
    László Monda not to mention that the sound quality is terrible.
    daman this is just a high voltage power supply
    when it is connected to a vacuum tube of sort whether it is a crt or a laser tube or a light bulb or vacuum tube based rectifier diode it will produce xrays.
    grenadier i think ozone is produced from anything that ionizes the air.
    i guess if ozone can damage your work you could try using some cfcs to destroy the ozone like collect the freon from old air conditioners.
    the problem is you have a spark that may turn the cfcs into phosgene witch is deadly
  26. Singing arc (modulated carbon arc light), 1899:
    http://120years.net/machines/arc/
  27. Pass modulated arc through gas flame for amplification:
    http://www.swtpc.com/mholley/PopularElectronics/May1968/Flame_Amplification.htm
  28. 1000100 1000001 1010110 1000101 says:
    The .22 brass just makes it that much cooler.
  29. Mike says:
    I just got rickrolled on his page.
  30. Chris says:
    @Grenadier: Congrats on being featured twice on HAD in a single day, and still having a functioning server!
    In case it’s useful, some options for AC output from a flyback:
    1) Some people have successfully drilled/dremelled into their transformer just before the diode to tap into the unrectified output; but success rate seems substantially less than 100% (I tried once and failed).
    2) Old TVs that use separate voltage triplers have no rectifier in their flyback. Exactly how old (and large) a TV you’d need, I’ve never found out.
    3) Or just buy a new flyback without a rectifier. Check out “FLYEXP” at “www.amazing1.com/transformers.htm” for a nice assortment which includes some non-rectified ones. There may be other sources, it’s been more than a decade since I’ve looked.
  31. Curtman says:
    The Technology -> Perpetual Motion link was great.
    If only it had an Arduino..
  32. Bill Porter says:
    This is the same premise as the Tesla coils that produce sound. Pretty cool.
    @Chris, HAD traffic isn’t near server crippling potential even for a double post in one day, unless you self host I guess.
  33. barry99705 says:
    @Curtman
    Wait a day or two for the Gizmodo or Engadget folks to catch up. It’s not quite the /. effect, but it’s pretty damn close!
  34. grenadier says:
    Yeah I’ve got a great server. I think engadget might kill it though…
    @omgkittenz
    Trolololololo.
    @chris
    I know that, In fact I’m using an AC FBT in my next project…
    @ejonesss
    After 30 minutes there is still not a hint of O3 in the air.
  35. SpiralBrain says:
    About the circuit, is this a good way of driving mosfets? Also there is an absence of a snubber to damp the reverse kick. The protection diodes in the Mosfet look to be working over time.
    Isn’t the IRFZ44N a better option? do we really need a 200V Mosfet here?
  36. grenadier says:
    @SpiralBrain
    I used the 250 fets because I had about 20 of them. I’m sue the are better mosfets that one can use, but it was all a matter of convenience for me. Besides, the 250’s are pretty hard to kill.
  37. SpiralBrain says:
    @grenadier Thanks! So there is no real purpose for high voltage mosfets. I am very tempted to build one now.
  38. Dale says:
    But can you build it for stereo? For use as headphones?
  39. mjrippe says:
    Very nice project! I actually heard one of the “original” plasma tweeters – the Ionovac – many years ago and this was great to see. Those DuKane or ElectroVoice Ionovacs sell for big $$$ these days, perhaps you could make a marketable modern version?
  40. Whatnot says:
    I think there’s a very easy test to detect ozone, it’s your nose, ozone is very noticeable and there’s little doubt if you smell it.
    And yeah any spark makes some ozone.
  41. strider_mt2k says:
    So cool! -and I’m not gonna bitch about the music choice either.
    Can’t stop watching the music…must touch the OWWW THE MUSIC BURNS, THE MUSIC BUUUURNS!!!
  42. Mr Sceez says:
    @James Munns
    didn’t i catch you making one of these at the hardware hacking village at defcon a couple years ago?
  43. James Munns says:
    @Mr Sceez,
    Nope, wasn’t me. I know hackaday writers have attending defcon in the past though, so it could have been one of the older writers.
  44. This thing has to produce a lot of ozone. I did a great deal of research on this exact subject, and after less than a minute you could clear smell the ozone the arc is producing. And really who wants a fire hazard stereo combo? Sure the blue light is mesmerizing for the first few minutes, but after that all you will be left with is a space full of stanky ozone.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 92,407 other followers
