One really big quadcopter that is following in the steps of the Spruce Goose
Behold the Land-Bear-Shark, a quadcopter on a rather grand scale. At a full eight kilograms it’s an easy target to compare the [Howard Hughes] behemoth, but in addition to the weight, this still has yet to make its first flight.
To give you some scale to the image above, the board at the center is an Arduino. It controls the beast, along with the help of a SparkFun IMU board which rides atop. Really, if any quadcopter of this size has a chance of working, this should be the one. The construction is beautiful, making use of carbon fiber rod along with 3D-printed connectors to assemble the frame. A lot of thought has gone into small things like conserving weight used on the landing gear, which are incorporated into the bottom corner brackets. The batteries are connected in a manner that makes them easy to adjust, acting as ballast for balancing the craft.
We’re keeping our fingers crossed that this will be more than the tongue-in-cheek title of the post which calls it a Quadrotor-shaped sculpture.
[via Adafruit]
Comments
  1. MumbleFysh says:
    Still looking for a sweet video. We also need a separate Quadcopter section.
  2. Bogdan says:
    I really can’t wait to see and hear this thing flying!
  3. anonymouse says:
    This isn’t actually the LBS, it’s a tracked skateboard thing [1]. That one is called the “Emergency QuadRotor” [2].
    1: http://www.etotheipiplusone.net/?cat=70
    2: http://www.etotheipiplusone.net/?cat=81
  4. ChArLeSg says:
    Hey Mike,
    Quick error correction: The Land-Bear-Shark is actually one of my other odd vehicle projects, which is currently more presentable.
    You can find details on it on its summary page:
    http://www.etotheipiplusone.net/?page_id=1216
    A build report with video:
    http://www.etotheipiplusone.net/?p=1426
    The latest one, showing some… failure modes, but with better video:
    http://www.etotheipiplusone.net/?p=1473
    The quadrotor is just named “Emergency Quadrotor” at the moment, and does not yet have a project page. It might be better to wait until it either works or crashes epicly.
  5. M@ says:
    Wow .. that thing looks dangerous. I like it!
  6. BobSmith says:
    Looking on his website, the land bear shark is not the quadrotor, it’s some kind of tank tread thing.
  7. ChArLeSg says:
    Hi all,
    Mike has corrected the error in the post. Thanks!
    (Yes, the LBS is a separate project!)
  8. ???? says:
    This shouldn’t be on this website as it’s not complete.
  9. ???? says:
    Normally don’t like to double post but I noticed that the props are in the wrong orientation. And if you are going to use an Arduino, might I suggest ditching the standard and going for an Ardupilot with an Ardumoto board
  10. medix says:
    Where’d he get the fans? Never seen anything like this before..
  11. ZeUs says:
    Spruce Goose was wooden, that’s still a BIG step up.
  12. lwatcdr says:
    Those look like ducted fans and may be off the self. But they all seem to turn the same way so I am wondering about issues with the quad spinning. I know a good bit about helicopters and airplanes and not so much about quadcopters so I could be wrong. I mean you could defect the thrust to counter the rotation and provide yaw control but I thought they did it by couter rotation.
  13. madman1027 says:
    all of those fans turn the same way so the quad will just spin, it needs two to turn the opposite way to allow torque steering in both directions
  14. Darkknight512 says:
    @lwatcdr
    They can be either or, I just made one with counter rotating props, I’ve seen a few with thrust vectoring tho.
  15. Luke says:
    Holy shit. That’s pretty big. Counter rotating props simplify a design but are not completely necessary (or possible in all situations like a tricopter). I can hardly wait to see it fly!
  16. Itamar G says:
    Am I the only one that thinks this can NEVER work? (at least the way this guy’s doing it…)
    I don’t think he’s going to get anywhere near the required control bandwidth from a fixed vector, fixed pitch quad.
    In my mind, a larger quad will only be viable with either variable-pitch rotors, control surfaces, or full-on vector thrust capabilities…
  17. aEx155 says:
    I would like to point out that Land-Bear-Shark is a tank-treaded skateboard, not the quadrotor.
    The name of the quadrotor is the “Emergency Quadrotor”…
    http://www.etotheipiplusone.net/?p=1435
  18. Jon says:
    Having actually followed this project, here’s some more information
    1) This project is not called Land-Bear-Shark; that’s another of Charles’ projects. It’s called “Emergency Quadrotor” (for now)
    2) The ducted fans spin the same way and use 1-DOF thrust vectoring to correct for the rotation. Each fan mount is on a pivot and servo-controlled.
    3) The 3d-printed stuff was made on his DIY 3d printer.
  19. Buzzles says:
    Hhe’s the chap behing the LOLriokart and yeah, this isn’t the land bear shark (which set itself on fire and is now dead):
    This is his “Emergency Quadrotor”:
  20. knuckles904 says:
    Ambitious. What are those fans from? It’s gonna be loud if this is any indication.
    http://diydrones.com/video/ducted-fan-tricopter
  21. The Timmy says:
    I hope he doesn’t step on that soldering iron on the floor there.
    for a better sense of scale, just know that the floor tiles in that picture are probably 12 inches across, square.
  22. ovaltine says:
    Go to the source for this one. I’ve been reading this kids site for a while now. Its pretty rad you should check it out. also land bear shark is a two tracked vehicle, not this copter…
  23. cgimark says:
    That is going to take a lot of thrust to get off the ground. The props are really too small for something so heavy so they are going to have to get some really high rpm going and that means low battery life.
    I have seen one similar but it was done with a tether to the power supply and not using batteries, the current draw was 12vdc @ 9A . Not something well suited to batteries and light weight.
  24. Ted says:
    Ducted Fans? Really? Ducted fans are all wrong for a copter, they don’t work well at all when hovering, they need airspeed moving through the fans to be efficient. Really need to go with propellers here.
  25. Dino says:
    I hope this thing flys well. I’d love to see all the nay sayers proven wrong. :)
  26. Silver says:
    This is not the land-bear-shark, that is a project for a remote controlled motoriesed tracked skateboard.
    this is a project known loosely as ‘Quadrotor-shaped Sculpture’
  27. emissary says:
    Whoever wrote this article screwed up:
    The Land-Bear-Shark is a two tracked all-terrain skateboard.
    This is the Emergency Quadrotor.
  28. ilektron says:
    This thing will never work, or will struggle greatly. You can build a quad without counter rotating props, you just angle two opposing ones. The size of the quad is not a problem. Larger quads have slower time constants. The problem is the EDFs. They provide low thrust/weight. Plus, they will respond too slowly to command inputs. EDFs are also terribly inefficient. Good luck, sir!
  29. aEx155 says:
    There are so many comments here that would have been answered if Hackaday had chosen a better post to link to:
    That way, people who click through to the post get the beginning and not some middle one.
  30. KillerBug says:
    Why do I get the feeling that this thing will work more like a hovercraft than a quad-copter? I really don’t wish him misfortune or anything; it just does not look like it will fly in the way that a quad-copter does.
  31. foogoid says:
    Wow,
    EDF’s for static thrust? Good thing he’s got those huge batteries.
    On the upside, it can probably climb REALLY REALLY fast.
  32. hammy says:
    One of the aerospace students here wrote a thesis on why using ducted fans for micro UAV thust is a terrible idea. The gist of it was that power use versus thrust for ducted fans is extremely poor in comparison to using wider props (not to mention higher sound amplitude and frequency!)
  33. lwatcdr says:
    @Darkknight512 contra rotating is the way to go. Why waste thrust for anti-yaw when you don’t have to? And thrust vectoring if you need extra yaw authority. The one issue that you may have would be prop availability. Ducted fans vs props is a whole other issue. For maximum efficiency you want the largest prop possible in hovering flight. I am not an expert on ducted fans but I do know that outside of turbofan engines they have not been popular in aircraft. And I have never seen a production aircraft use a ducted fan for vertical lift outside of the F-32.
  34. BobSmith says:
    He didn’t actually correct it in the article. It still says the wrong name.
  35. Richard says:
    perhaps he will be able to boost his hover efficiency with some Avro car style coander effect
  36. Crizz says:
    it´s much easier to control a EDF-powered tricopter. Did the job using 3 pcs of 2,5″ ( 64 mm ) EDF w/ 4300 k/V outrunners on an Arduino-based control. Take-off weight is at 1100 gr. w/ 3s-2200 Lipo , sucks 45 Amps in hovering and joyride. I did two ways of yaw control and torque compensation : one way is tilting the yaw-EDF, the other is a thrust-vector control with flaps on the airstream outtake.
  37. Dan Fruzzetti says:
    I look at that and think, strange choice of fan for the form factor…
  38. Crizz says:
    ducted fan is indeed the worst choice, it´s simply energy wasting. In my case , efficiency wasn´t the goal – it was just about possibility, but it´s fun to fly it. Most efficient would be Schuebeler-EDFs, but most expensiv too ;)
    IMU w/ magneto is recommended, it´s a big advantage in flight stability, works better on mine than use of acc.-sensor.
  39. Thomas Lewis says:
    Big is cool,check out Hobby Kings beer lifting contest if you want to see some big and super powerful quadrotors,these are capable of carrying your little brother or sister to 5000 feet,haha.I don’t have the link,but the Hobbyking site has it.
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
