Video: PWM on the ATmega328p
This week we continue on with another video in our series about how to program for the ATmega328p processor using C. The ATmega328p is at the heart of many Arduino boards. If you have been using them but want to add some more horsepower to your projects, this series of videos is for you. In this video, [Jack] talks about various types of pulse width modulation (PWM). You can use PWM to control the speed of a motor, the brightness of a LED, or to generate analog waveforms. [Jack] shows how to set up the processor to do locked anti-phase PWM to drive the wheels of the 3pi robot and then demos a short program that shows the code in action.
If you missed the previous posts in this series and would like to check them out…
Intro and how to set up the development environment : Click Here
Working with I/O pins: Click Here
Video is after the break…
Comments
  1. Eraser says:
    Awesome, great video.
  2. Kirill says:
    This 3pi robots is quite neat. Great video
  3. fileoffset says:
    I would use graph paper next time, so that you can show how the pulse width/frequency compares with respect to time, easier.
    Also, I have to disagree when you say that pre-calculating the values of registers (i.e REG = 92) is ‘just as good’ as OR’ing each bit together. OR’ing each bit, as you do in the tutorial should be recommended for all developers, as it is _much_ more descriptive, easier to understand and much easier to modify at a later date, if necessary. It is just good practise.
    Also, that high pitched whining is god-awful annoying but you don’t mention if it is actually bad for the motors or any of the components driving the motors? Are there any repurcussions to doing it this way? Will it burn out motors if you run it for long periods at 128/128?
    Thanks for the tutorial, it’s fun to see how fast that thing can zip around!
  4. mail junky says:
    Neat. I am not into the arduino, but I sure could use those ideas with pc robotics.
  5. really good video,makes it easy to understand.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 93,658 other followers
