Hackaday Links: December 7, 2011
LED Neurons
[Alexandra Olivier] put up an art installation at Wellesley College that looks like a bunch of neurons built out of LEDs. The neurons are connected to a couple PIR sensors and ‘fire’ whenever movement is detected. The result is a lot like being inside a brain. Fitting, then, that the installation is called Social Synapses.
Last year’s big toy was always evil, though
Last year, [Andrew] had to fight the throngs of shoppers to get the must have toy of the season, a Zhu Zhu pet. Since these robotic hamster things have spent the last 11 months in the back of a closet, it seems reasonable to make them evil. They’re still not as evil as a demonic Furby….
So we call it a bifocal, right?
There’s an old photography trick for a really hacky macro setup – just turn the lens around. Well, what if you wanted automatic metering and flash control? Simple, just electrically reverse the lens. Bonus points for being able to use the lens regularly as well.
Control all the bands
Well here’s something cool: an all-in-one USB 315mhz, 433mhz, and 868mhz transceiver. What can you do with it? Well, [codeninja] can control the outdoor lights for two of his neighbors, open gates and doors, crash his weather station, and just about anything else in those bands. It’s pretty much like war driving for important stuff nobody cares about.
So this is our favorite holiday now
There’s a Dutch tradition to play Sinterklaas and make someone a present. [Jenor] decided to build an antique-looking DC voltmeter with a pair of vacuum tubes. The tubes don’t work anymore, but the heaters still provide a nice warm glow. It’s a bit large to be regularly used as a piece of test equipment, but it really does look awesome. Very steampunkey, and it’s the though that counts anyway.
Comments
  1. AZID says:
    No link for the usb scanner?
  2. sonofabit says:
    why there’s no link whatsoever for codeninjas project?
  3. sonofabit says:
    a bit of research and BANG here goest the link :) http://codeninja.de/sc4nn33r/
  4. Christian HC says:
  5. Tryum says:
    Isn’t the link missing for “Control all the bands” ?
  6. Jeff G says:
    HackADay needs to update the link for the USB ISM-band WIFI router!!! (http://codeninja.de/sc4nn33r/, as the comments have shown)
    but, can anyone find more info about this? I’d like to know the software / especially the hardware for the transceivers / receiver+transmitters used
  7. Drake says:
    I too would like more info … couldn’t this be used with the chronos for reverse engineering communications and such? Also home automation made easy for unknown hardware?
  8. miked says:
    good timing on the scanner. i was just looking up garage door scanners.
    details would be nice. most of the comments on codeninjas page ask for them.
  9. Chiablo says:
    Am I the only one who thinks the last one is really stupid? If you are going to be using tubes, at least use them for their intended purpose. Adding tubes for the sake of aesthetics is like installing a bunch of stepper motors to the side of your voltmeter because they sound cool.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 92,427 other followers
