Simple hardware and Python drive this Splunk LED meter
Want to monitor the company system without continually loading up the Splunk dashboard? It turns out that they’ve got their own Python package which makes pulling down data a snap. All [Rick] needed to do was hook up an LED meter as an external display.
It used to be that this would take a lot of wire and bit of soldering (or some special Christmas lights), but the advent of affordable LED strips has really taken the guess-work out of it. He’s using an RGB version acquired from Adafruit Industries. These strips are driven using SPI and multiple-colors mean you can display multi-dimensional data using one column. He chose to use a Teensy microcontroller, grabbing some plastic packaging for welding rods as the enclosure. These strips are extremely bright and to help soften the impact he added wax paper to the inside of the enclosure to act as a diffuser.
Looking for more projects that use strips like this one? They make fantastic addressable accent lighting for your home.
Comments
  1. I submit to you BeBox Blinkenlights.
  2. Cyril says:
    Wow that’s a fancy way to do it. Usually I just ask: Did that taste good?
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
