Playing around with MRAM
For the longest time, hardware tinkerers have only been able to play around with two types of memory. RAM, including Static RAM and Dynamic RAM, can be exceedingly fast but is volatile and loses its data when power is removed. Non-volatile memory such as EPROMS, EEPROMS, and Flash memory retains its state after power is removed, but these formats are somewhat slower.
There have always been competing technologies that sought to combine the best traits of these types of memory, but not often have they been available to hobbyists. [Majenko] got his hands on a few MRAM chips – Magneto-Resistive RAM – and decided to see what they could do.
Magneto-Resistive RAM uses tiny pairs of magnetic plates to read and write 1s and 0s. [Majenko] received a sample of four MRAM chips with an SPI bus (it might be this chip, 4 Megabits for $20, although smaller capacity chips are available for about $6). After wiring these chips up on a home-made breakout board, [Majenko] had 16 Megabits of non-volatile memory that was able to run at 40 MHz.
The result was exactly what the datasheet said: very fast write and read times, with the ability to remove power. Unlike EEPROMS that can be destroyed by repeated reading and writing, MRAM has an unlimited number of write cycles.
While MRAM may be a very young technology right now, it’s a wonderful portent of things to come. In 20 (or 30, or 40) years, it’s doubtful any computer from the largest server to the smallest microcontroller will have the artificial separation between disk space and memory. The fact that any hardware hacker is able to play around with this technology today is somewhat amazing, and we look forward to more builds using MRAM in the future.
Comments
  1. Ren says:
    Just as HaD reported a while back about someone testing the read/write cycles of an MCU chip, maybe the “unlimited number of write cycles” of these chips could be checked.
  2. rageahol says:
    dont some of the msp430s use this already?
  3. 0xfred says:
    The MSP430s use FRAM (Ferroresistive) and you can also buy them separately. A quick look on Wikipedia and I’m not really any wiser as to the material difference between MRAM and FRAM.
    • ginbot86 says:
      It’s ferroelectric, not ferroresistive like you said.
      MRAM and FRAM are both nonvolatile but have a different means of holding their data.
      MRAM uses ferromagnetic materials and therefore are susceptible to external magnetic fields, much like hard disk drives.
      FRAM uses the polarization of a material to hold data; a layer of lead zirconium titanate (PZT) is used as the storage element. As far as I know, neither magnetic fields nor ionizing radiation will affect FRAM. It technically has a read-write limit, but it’s able to do trillions of reads and writes over its lifetime.
      @rageahol
      MSP430s don’t have an MRAM line, but they do have FRAM (see my previous statement).
  4. nes says:
    Very nice, but it’s hard to think of a hobbyiest use which is constrained by write time. The serial bus is the bottleneck when reading EEPROMS and 40MHz is a somewhat standard speed. When writing, having a page pre-erased ready and just appending new data speeds things up quite considerably.
    If these RAMs had a parallel interface it would be a bigger deal IMHO.
  5. cjwoodall says:
    FRAM is also pretty neat, but unlike MRAM which has “infinite” number of write-erase cycles, FRAM has an extremely large number of write-erase cycles. For example, Wikipedia says 10^6, which is quite a few. You can get types that go at 40MHz.
    Example: http://www.digikey.com/product-detail/en/FM24V10-GTR/1140-1076-1-ND/3178438
    Regardless, MRAM is cool!
  6. timg says:
    FRAM and MRAM are very different in the way they work.
    FRAM basically replaces the oxide in the capacitor of a DRAM like cell to achieve its non-volatility.
    MRAM introduces a new storage element in the form of a resistor (called a Magnetic Tunnel Junction or MTJ) that can be put into 2 distinct states with different resistances.
  7. James says:
    @nes, check the Everspin website. MRAM tech is also available in 8 and 16 bit interfaces.
  8. jc says:
    Might be interestring to try to get linux with xip working on those things. Can’t wait till they’re reasonably large, though
  9. DerAxeman says:
    Magneto Resistive RAM doesn’t actually have truly unlimited write cycles, but I wouldn’t loose any sleep over worrying about it. If you notice the literature from Ramtron or Everspin they all say “Virtually unlimited write endurance”. Last thing I read said you could do nothing but write to them for several years before a failure.
  10. bdsmith says:
    FRAMs have been around for a long time, made by Ramtron. I just assumed that, since there wasn’t any competition, that they had a patent on them. I guess the patent has expired. They are pin-compatible with EEPROMs and use the same s/w, except they don’t need the write wait time. I used some in a datalogger that went in a model rocket so I could have non-volative, fast storage.
    • yeah… same pinout. I managed to get some FRAM samples from ramtron, the i2c version, 128 kbytes, so 17 address bits… one of them lives in the i2c address byte.
      The only problem is that this high-order address bit is NOT at the same place in the i2c address byte as EEPROM chips like the 24AA1025, so they are NOT I2C-Address compatible, so that you cannot mix, say, 2 EEPROM and 2 FRAMs on the same I2C bus.
      That was quite a deception, meaning that my design would only be able to use the 4 fram samples I received, or 4 standard EE devices, but not a mixture of both.
      That’s a good thing to be aware of if you’re trying this.
  11. Christophe says:
    I really hate it when I read someone provides “virtually unlimited” something. Nothing is virtually unlimited, everything has a hard limit. The universe has a finite number of atoms and a finite size. To Nokia: my dumb cellphone does not have “virtually unlimited” SMS contacts, it’s just quite large, and I’d like to know *exactly* how large. Any company that claims to provide a “virtually unlimited” supply of anything instantly raises to me red flags.
  12. cloudscapes says:
    I’ve used those very MRAM chips before in a test project. I think I might like to use them in a proper thing.
    For me personally, the most appealing thing isn’t the uber fast write times or the non-volatilibility (?)…. just that it’s one of the few RAM chips that support SPI and has nice capacity. The alternatives for that much storage with SPI are FRAM at double or triple the cost, in hard to use BGA, or Microchip which have *finally* just come out with 1meg versions of their SRAM chips, very cheap, but still only a quarter the storage space so more real-estate.
  13. Galane says:
    Are MRAM or FRAM related to the magnetic bubble memory that had a rather short use in the 80’s? (Mostly in one of Radio Shack’s pocket computers.)
    To me, FRAM is a company that makes oil and air filters. ;)
    As for “unlimited” things, when I got my first cell phone from Verizon, with unlimited night and weekend minutes, the brochure with it had printed on it that the “unlimited minutes expire first”.
    Que? If they’re unlimited, how can they expire, let alone expire before the limited daytime minutes???
  14. Tim says:
    What I am curious on is, is there a substantive difference between MRAM and FRAM and similar (e.g. phase-change RAM) other than the unlimited vs. may-as-well-be-unlimited write cycles? For example, one thing I’m really interested in is power consumption per unit of data written. Does one from the technology standpoint have an inherent advantage over the other?
    I had not heard before that MRAM could be wiped by external magnetic fields. Good to know.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 96,405 other followers
