Building a rather rudimentary Arduino tank bot
building-an-arduino-tankbot
The tank robot builds that we see are often quite complex. This lets them do great things, but makes the platform scary for beginners. Here’s a tank build that would be a great first project, especially if you’re more interested in the programming side of robotics than you are in the hardware itself. [Paul Bleisch] combined several different commercially available products to fabricate this Arduino-powered tank robot base.
Locomotion is provided by a double geared-motor module. This unit, the plastic wheels and treads, as well as the wooden mounting platform are all made by Tamiya. They cost very little and are already designed to work with one another. To this base he adds the Arduino and a motor shield which makes the connections dead simple. The black case on one end of the chassis holds four AA batteries which provide power for everything.
These components are all that’s really needed to start, but they provide no interactivity. So [Paul] picked up a used wireless PlayStation 2 controller. There’s a library (written by regular reader [Bill Porter]) that allows him to connect the receiver to the Arduino in order to pick up commands from the controller. He also plans to add an ultrasonic range finder to the build sometime in the future.
If you’re don’t need to do things the easy way you should consider fabricating your own tank treads.
7 thoughts on “Building a rather rudimentary Arduino tank bot
    1. Had the same problem especially when turning. Try implementing a decceleration (sp?) algorithm to slow the treads down a little bit instead of snapping the drive train into the opposite direction.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
