DIY Laser Cutter Built To Make Stencils
It was time for some new T-shirts so [Andreas Hölldorfer] built a laser cutter. Wait, what? That’s the excuse he’s going with, and in the end this scratch built laser cutter did come in handy by cutting stencils to use when decorating his garments.
The first thing we thought when looking at the cutter is where’s the tube? [Andreas] didn’t use a CO2 laser, so this ends up being rather low-powered. The cutting head is a 1W blue laser diode which manages to slice the three-ring binder separator pages he’s using for the stencils. The two-axis machine is mounted inside a wooden box to protect his eyes while it’s cutting. He plans to add a drawer later on so that the cutting bed will slide in and out to swap out material for the next project. He already does a lot of 3D printing work and had an old RepRap driver board on hand to use for this projects. He designed and printed the red mounting brackets which make all of the junk-bin components work together. Not bad!
If you’d like to try this out on a smaller scale try using optical drive parts for the axes.
34 thoughts on “DIY Laser Cutter Built To Make Stencils
  1. ” A 1 Watts blue laser diode will be enough to cut through a thin plastic sheet, that’s all I need. Everything else is routine.”
    rofl
    this dude rules
    1. That was my first thought too ;)
      Would it be possible to mount a camera inside (and a led if neccesary) ?
      Or does the laser damage the camera chip like it does with a human eye ?
      1. As long as it’s not a sustained direct hit, a camera would probably not be damaged. Most CCD chips that I’ve worked with can handle momentary blasts of laser light, even short wavelengths. YMMV.
      1. You don’t think the box can handle a 1-2 Watt load indefinitely?
        Maybe if the focused laser were concentrated on a single point for a long period it’d be a problem, but I’m pretty sure the box will survive the distributed heat load.
        Fume extraction is still probably a good idea when ablating and melting plastics, but it could potentially be safe if the volume of material removed is small and the area is well ventilated.
        An interlock would be easy to implement and is critical to safety in this build, but it’s otherwise one of the few laser hacks I actually find tempting!
  2. Just out of curiosity, if it was an actual medium powered laser that could cut through things like wood and acrylic, would this be enough shielding, or would the case need to be made of metal and/or special glass?
    1. Generally, lasers used for cutting are absorbed by almost anything – a laser that simply passes through the workpiece is worthless. A CO2 tube is perfectly safe behind regular glass or acrylic/polycarbonate. The thickness of the enclosure is up to you but they rarely take prolonged laser hits.
      The most common mode of catastrophic failure is the workpiece catching fire. Since the boxes are well ventilated it can become spectacular pretty fast which is why most cases are non-flammable sheet metal.
  3. Neat, but not the way to do T-shirts. you can do screen printing very easy and dirt cheap by simply printing onto a transparancy and exposing a screen treated with the emulsion to sunlight.
    Still a laser cutter is cool, Even cooler it should be able to laser engrave wood causing you to be able to make epic cool stuff.
    1. Because it goes nicely with the flammable paper he’s cutting. Gasoline evaporates nicely, maybe it would be a good coolant for the paper?
      On a more serious note, anyone ever tried a laser like this on styrofoam?
  4. Just me that read the title and assumed SMD solder stencils then?
    Nice build though. I won’t make any comments on safety as I have a (small) permanent scar on the back of my hand from a 40W CO2 laser.
    1. The 40W Chinese lasers you see on eBay are great value – if you consider them to be a kit if parts and you’re happy replacing the bits that fell off in transit and ditching the awful controller board. You can buy just the 40W CO2 tube and PSU but it’s not that much cheaper.
Leave a Reply to Tom KaneCancel reply
